Question about Edimax BR-6104K Router (br6104k)
Edimax br-6104k my isp is smartbro, and have 4 pc. when i connect my modem to my pc i can easily access the internet, but when i connect the br-6104k i cant access intrnet. please help. thank you. labuyo7
  • Ryan Trumbull
    Ryan Trumbull May 11, 2010
    What is the IP address of your computer when connected to the modem? If you are using Windows, goto Start, select Run, and type CMD (or Command on versions 98 and below), then type 'ipconfig', your IP address will be listed.
    Problem Solver:
  • 5 Answers
Try to contact your ISP and tell them your problem.
Posted on Mar 24, 2012
Do you have apppoe connection or dhcp? release your ip address (ipconfig/release) set your modem to bridge mode then connect modem and router. try to connect.
Posted on Feb 03, 2008
Your router internet settings should depend on your ISP connection type. If you are on DSL, either your setting is PPPoE or just obtain IP automatically. If you have a username and password from ISP, select PPPoE and specify your username and pw. Check on the internet/WAN status if it says "Connected" and if it has Internet IP address.
Your modem should be plugged in to the internet port of the router while both your computers should be on plugged in to the LAN ports (numbered ports).
You may contact your router manufacturer for step by step assistance on the router setup. They should be able to restore your connection.
Apr 09, 2009 | Edimax BR-6104K Router (br6104k)
Asks for IP address and password
Try reading the Quick Installationguide and see of that helps.
Nov 03, 2008 | Edimax BR-6104K Router (br6104k)
PPPoE over Edimax BR-6104K without a modem
I am not sure if I understand you well.
You say:
My Internet is a PPPoE broadband connection but I don't have a modem installed.
What do you mean ?
You have a Broadband/ADSL modem, but you didn't install any software for it ?
(It is probably not necessary.)
So, I assume you do have a modem. You connect your modem to the wall outlet with a telephone cable.
Then then modem is connected with LAN cable to one of your PC with two NICs, you make Internet Connection Sharing, and ten from the second NIC of that PC, you connect (again) with LAN cable, your second PC.
If it is an ADSL or Cable modem connected with LAN cable, please follow this steps.
First RESET your Edimax router and disconnect all LAN cables if connected.
Connect your PC (the one with one NIC) to one of the 4 LAN ports of your Router wit a LAN cable.
Open My Network Places and then View network connections, or go to Control Panel and open Network Connections.
Right-Click on your LAN adapter and choose Properties, then double-click on Internet Protocol (TCP/IP)
Set to 'Obtain IP address automatically' and 'Obtain DNS server addres automatically' (click OK). Now you are back to the previous window. Click and check (if it is not) 'Show icon notification when connected' and once again click OK.
After a fiew seconds you should get (near to the clock in the the right bottom of your desktop), a Network icon and a baloon message that your NIC is connected.
Right-click on the network icon and click STATUS, a window will open
and then click on SUPPORT tab.
You should see:
IP Addres:
Subnet Mask:
Default Gateway:
Open your browser and type
Now login as:
admin (default)
and password is: 1234 (default)
Click on GENERAL SETUP on Top-Left, and then on WAN (on the right side) and choose
Click on 'More configuration'
Type your User Name and Password you have from your ISP.
Now Click on APLY, and again APLY !
The Router will restart in 30 Sec, and your NIC will reconnect.
Now connect your Modem to a WAN port of your Router with LAN cable. (***)
if you've typed your User Name and Password correctly in PPPoE fields,
if everything is OK with the service from your provider,
you should now be on Internet.
If not, then please check your User Name and Password with your Internet Service Provider, and ask them if they can see your router.
Now, get to the PC with two NICs.
Go to Control Pannel, and go to Network Connections.
Right-click on one of your NICs and click 'Disable'.
Check the other NIC if 'Internet Protocol (TCP/IP)' settings are set to Obtain IP addres and DNS - Automatically, and 'Show icon notification when connected' and once again click OK.
Connect the (enabled) NIC with LAN cable to another port of your router.
The second PC should be on Internet, too.
If you (somehow) realy don't have a modem, but you have a cable only, follow the above instructions to the point (***) and connect the cable to the WAN port of your router.
That's it!
Aug 28, 2008 | Edimax BR-6104K Router (br6104k)
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix
Jul 10, 2008 | Edimax BR-6104K Router (br6104k)
How to use edimax br6104k with an smartbro isp
It's not a problem connecting to internet if your isp is smartbro, esp. if you are using a D-Link router..just plug in ur smartbro rj45 to the WAN port and connect ur pc to one of the 4 LAN port of the router that's all you can connect to internet..first time of course u have to input the username and password from smartbro in order to connect again..
May 20, 2008 | Edimax BR-6104K Router (br6104k)
Port Forwarding with BR-6104K
hope this helps
In vegas to forward a port with the zytell modem Sprint/Embarq our DSL provider you have to bridge your modem first and allow your router to pull your IP from your ISP. Then you can forward the port.
If you have DSL I would start by going to my ISP's website and look for instructions for setting up port forwarding or Bridging your modem.
Bridging your modem passes off traffic control to your router. on zytell modems you can also forward ports but bridging is much less technical
I have not run into CABLE providers cable modems having to do this
did you allow that port in your computers firewall?
Did you set up a static ip on the computer you want to forward your port for? sounds like it is required for you router
User manual:
instruction site
to test the port connection you can go to on the left pane click on port scanner and choose custom to scan the port number you are attempting to open. you do have to have the application that will use that port running to get a result if it is a game ALT+TAB should let you out of the game without shutting it down to open a web browser this tool can save you a lot of time testing the port it will give you a open status when you have succeeded.
Mar 29, 2008 | Edimax BR-6104K Router (br6104k)
Page Cannot be Displayed-IE, Edimax Router BR-6104K
Smartbro account is used directly to the computers LAN port, not on the router, One computer should be made as the server, where the smartbro connection is placed... to share the internet connection... you should have another LAN card to share Internet throught the router... "See New Network Connection" you'll see examples of proper connection.
Good luck... Fixya...
Feb 02, 2008 | Edimax BR-6104K Router (br6104k)
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
Cant connect
Hi nometz,
Smartbro has their own wireless security which called mac address filtering. This issue was already experienced by their olders subscriber's. Since, Smartbro connectivity is only good for personal used, they used to block any unrecognized mac address encountered with their network because of network abused such as sharing of internet connection and used for business internet cafe.
If your router has mac address cloning features that's possible you can used the internet using your router.
If my solution sound helpful please don't hesitate to ask me. I am here to extend my helpful ideas to you.
Best regards,
Oct 21, 2007 | Edimax BR-6104K Router (br6104k)
Edimax BR-6104K Router (br6104k) Logo
249 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
