Question about Mitsubishi VS-50605 50" Rear Projection Television
Television I have a projection television and the picture is not clear. It seems as if the colors overlap and it gives the double effect with a shadow. There is a slight wedge on the side of the television.
  • lastmitsu Feb 23, 2008
    I have a mitsubishi vs-5059, last night I did an A/V reset and the colors are out of alignment, and there are slight warp edges on boht sides, the "alignment" setup doesnt help, I am a Certified Electronics tech, I can do the soldering work, but need to locate chip in cirtuit board and also purchase the chip for this model. please advice.
    thank you
  • 3,130 Answers
You will need to have what's called the convergence correction IC's replaced. This is not really a hard job to do but takes a skill of knowing how to solder and unsolder on printed circuit boards. A pro could do this repair and clean the optics for less then 400 bucks. Good Luck
Posted on Jan 22, 2008
It has double images. The words are doubled even, appearing blurry. We are currently playing a DVD "daddy daycare" The words on the car are unreadable because they overlap. At the bottom of...
Ur tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv have a dead convergence board to causes these problems.The tv convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 28, 2011 | Sony KP-46WT500 46" Rear Projection...
How do i fix my samsung 1080i hdtv. It has a double picture and is red and blue, and also looks like a bow tie effect
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved pictures convergence problems.The shop,will cost u like $300-$350 for parts and labors.
Nov 21, 2010 | JVC AV-48WP74 48" Rear Projection...
We have a blue tint and a shadowing effect that makes it appear to have a double on the screen of the same figure / word(s)
This problems is known as a convergence problems,it dead.The R,G,B colors lines mis alignment,have colors shadows or picture look like 3D pictures.The tv convergence board,it dead.Require,must be changes 2 STK convergence ICS and some or all it resistors to solved tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 02, 2010 | Hitachi 53FDX20B 53" Rear Projection...
This tv have convergence problems,it dead.Red,green,blue misaligns colors,have colors shadows,3d colors pic like.All these problems are the convergence board have 2 STK convergence ICS some or all it resistors are dead.These parts must change to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Images on screen are doubled. Everything
u have bad convergence ic stk392-110 or stk392-150
Apr 13, 2010 | Hitachi 53UWX10B 53" Rear Projection...
If the entire screen is curved, and it is not taking the whole screen, then you have a vertical deflection problem.
If the colors are double and do not match, with lines of different colors around pictures , then you have a convergence problem, often caused by a faulty convergence board.
The curving effect can be a side effect of bad convergence, or you may have both problems at once.
Unless you are a TV repairer yourself, better calling technical support. Usually you can ring the number listed on the owner manual.
Jul 21, 2009 | RCA P52920BL 52" Rear Projection...
Blue and red overlap shadowing
convergence ic's are your culprit. they are responsible for aligning the 3 colors your tv projects onto your screen..
Mar 15, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Blurry shadows in red and teal.
Just click below for convergence repair kit;
Picture look double and the colors red come out the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Sep 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Shadow effect
I think it's called "tubes" for the TV, the projection tubes are messed up, and you probably killed your bulbes. Very expensive to fix, just part out what can be used and get a new TV, or get a 60" tv with a smashed screen, and reuse your screen. People sell those on all the time with broken screens because they do not know how to replace them for only 100-200$
Apr 05, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Colors not matched
Yes,there are convergence alignment adjustments, to be adjusted
by a technician after set is repaired.Replace STK392-560 IC's,then
check alignment..........T.
Oct 28, 2007 | Sony KP-51HW40 51" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
