Question about Polaroid FLM-3201 Television
TV flickers when turned on
When i turn on my Polaroid FLM-3201 the picture flickers like a fluorescent light that is about to burn out and i also hear a very faint flickering noise. The TV is about 3 or 4 years old is it about to die?
Thank you, Jim
  • Jorob525 Apr 30, 2008
    TV flickers when turned on problem, If the TV has been off for a few hours, like in the morning or when i come home from work,after its been on about 5 mins the flickering stops, then if its turned off and back on everything is fine, It appears like a problem when its warming up, but i thought they quit using tubes in TV's a while back, lol. Any suggestions from anyone, thanks.
    Sergeant:
  • 395 Answers
This sound like panel or inverters that drive the lamps ( fluorescent lamps that are not replacable they are part of the panel).
Posted on Jan 20, 2008
6ya staff
SOURCE:
Polaroid FLM-3201 TV picture flickers continuously, what causes this?
Check and replace the bad CCFL lamps inside the panel. This is due to backlight problem.
Jul 10, 2012 | Polaroid FLM-3201 Television
My Plaroid FLM-3201 LCD Television takes 4 hours to come on.
The power supply could be on the way to failing completely.
Aug 26, 2017 | Polaroid FLM-3201 Television
My polaroid flm 3201 tv won't turn on
This is an indication of a protective shutdown. During the startup process, a problem was detected and the unit shutdown to prevent further damage. There's not a lot to go one here. Some measurements need to be taken in side the unit to be sure. A common failure is the capacitors on the power supply board. Any local service shop should be able to get you a reasonably detailed repair estimate. Post the diagnosis here and we should be able to walk you through the actual repair.
Dan
Nov 03, 2009 | Polaroid FLM-3201 Television
FLM-3201 will not turn on
You can download service manual here:
http://www.polaroidsupport.com/polaroid/en_us-sm.html
Look for bad capacitors, burnt parts in the power supply first.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Oct 05, 2009 | Polaroid FLM-3201 Television
Picture takes almost an hour to come on
Replace swollen capacitors on power board.
Aug 29, 2009 | Polaroid FLM-3201 Television
Flm-3201
Sounds like the back light is out, and the unit needs servicing. You can check this by shining a flashlight close to the surface, and if some image is seen, the the back light is the cause. Else the LCD driver is gone.
Aug 03, 2008 | Polaroid FLM-3201 Television
Flm-3201
my polaroid model #3200  does'nt come on!  the light goes from red to blue and nothing,the picture stays black with no flashing or flickering
Apr 01, 2008 | Polaroid FLM-3201 Television
Polaroid flm 3201 wont turn on
If you have no power light at all on the front of your tv. Check the fuse by the power coard.
If you have a red light only and have the dark power board with black heat sinks. check the fuse in the center of the power board.
if the light turns blue when you hit the power button but no picture and have the dark power board replace the 2- 1000 mfd 10 volts caps with 2- 1000 mfd 16 volt caps at 105 deg.
need more help let me know
Nov 24, 2007 | Polaroid FLM-3201 Television
Polaroid FLM-3201
Check the fuse near power supply.
Cost to replace about $35.00
Oct 11, 2007 | Polaroid FLM-3201 Television
Polaroid FLM-3201 Television Logo
635 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
