Question about Samsung SGH-d807 Cellular Phone
Complete meltdown my phone for a while would not respond now it will not turn on...when i press the power button the only thing that happens is the key buttons light...if i can not fix it is it possible to get my stored pictures and such off the phone?
  • 2 more comments
  • alexfrankbob Jan 16, 2008
    i think i figured it out there is a large flat wire looking thing that is broken in the phone how do i get another one
    how do you take the three main pieces apart compeletly
    this are the bad images of the part i need can you tell me where to get it...the print reads sgh_d807_revo.9_60mm 2006.02.22
  • alexfrankbob Feb 10, 2008
    do you know what the "mother board" of this phone is called i fixed it early i just could not find the name of the piece i needed so ya
I foud it from this website: http://www.cellulardr.com/D800FlexCable.htm
It's cost about $20,
Posted on Aug 19, 2008
    Brigadier General:
  • 7,752 Answers
Sir...it would be best for you to take the phone to a mobile service center or mobile tech and have them replace the flexcable for you.
Posted on Jan 29, 2008
6ya staff
SOURCE:
I have my brothers droid moto phone he passed away and I want to get it hooked up to Verizon but do not know his password. How can I clean the old password off of the phone and install my password.
Hi @Rock Aduh , are we talking about the password to go in to the phone? If it is, please perform a factory reset.
1. Ensure the device is powered off.
Note If the device doesn't respond to input, press and hold the Volume Up/Down button then press and hold the Power button. When the device screen goes blank, release the Power button while continuing to hold the Volume Up/Down button then proceed with step 3.
2. Press and hold the Volume Up/Down buttons then press the Power button.
Note When presented with the Boot Mode Selection Menu, release all buttons.
3. Press the Volume Down button to tap Recovery then press the Volume Up button.
4. From the DROID triage screen:
a. Press and hold the Volume Down button.
b. Press and release the Volume Up button.
c. Release the Volume Down button.
5. Select wipe data or Factory Reset.
Note Utilize the volume keys to highlight and the Power button to select.
7. Select Yes -- delete all user data.
Note Data wipe may take several moments.
8. Select reboot system now.
Note To set up the device after the reset has completed, refer to Initial Activation and Set up.
Hope this helps. Factory Data Reset Powered Off DROID RAZR RAZR MAXX by MOTOROLA
Oct 30, 2017 | Verizon Cell Phones
Samsung galaxy s5 will not hard reset
Hi Anthony
  1. From your home screen press the Apps icon in the lower right corner.
  2. Find and press the Settings icon.
  3. Scroll down to the users and backup section and press the Backup and reset icon.
  4. At the bottom of the next screen press where it says Factory data reset.
  5. Hit the Reset device to complete the process.
Second way of resetting your Galaxy S5.
  1. Press and hold the power button to turn the device of.
  2. If your device does not respond, remove the battery and put it back after a few seconds. ( Don't turn it back on )
  3. With your device of press and hold the volume up and the home button, then without releasing the two other buttons press and hold the power button as well.
  4. Hold them depressed until your phone boots with the words Recovery mode in the upper left corner .
  5. To navigate the recovery mode screen use the volume up and down to go up and down. Use the power button to select an option.
  6. Press the volume down button three times until the Wipe data/factory reset option is selected.
  7. Press the power button to select this option.
Mar 04, 2016 | Samsung Cell Phones
While charging my ZTE Merit phone, the phone went dead. Does not respond to any pressing of any buttons. Only thing on is red return light bottom right of screen. What is wrong?
go on amazon and buy a New battery for $5.00+ and it will work for you, same thing happened to me. New battery solved the issue... well worth the 5.00$
Sep 30, 2014 | ZTE Merit Straight Talk
My unlocked iphone 3G won't turn on. Even with holding the home and on button and charging it in the car, computer and laptop. It's completely black
If the phone was soaked in water, you can try to put it inside your container where you put your rice in it for the water to completely dry up. If your phone fell to the ground, you may out of luck and have your phone checked up by an iPhone hardware expert. If those things didn't happen to your iPhone, you can try to press again your home and power buttons until you see the Apple logo. If you have a busted or unresponsive home button, try to press it harder to make it work.
Feb 25, 2011 | Apple iPhone Smartphone
My HTC Touch Pro turns completely off in the middle of the night
I think I have found out the way to solve this problem! I think! Ok on my phone I changed the power settings. Go to settings>all settings(if on touch flo)>system tab>power>advanced tab> then uncheck the two boxes that says "turn off device if not used for". Hopefully this works because I don't want to trade in my htc for another phone. Try it out and let me know if this works for you or not.
Mar 30, 2009 | HTC Touch Pro Smartphone
Blue light
Okay, I found a fix! Called JVC, spoke to somebody there, here it is:
1)unplug the TV completely, no wall no power strips, completely
2)wait 10 sec
3)plug TV back in and Turn it on, the light will still be doing the same thing
4)wait 30 sec
5)ON THE TV, not the remote, locate the menu, volume (-) and power button.
6)while simultaneously holding down the menu and volume (-) button, pressed the power button ONCE and continue to hold the other 2 for 10 sec.
7)on the remote control, go to menu>settings>system info
*** now this I know as a FACT will work on systems that display: JVC - ver.5.32FO001, but I don't know of any other versions***
8)press the mute button on the remote twice
9)unplugg TV again and wait 10 sec.
10) plug TV in and turn on
It SHOULD be working normally now... Thanx to the guys a JVC support for this one, I know it seems like an obvious first place to look, but sometimes it isn't. I for one checked online forums first.
Nov 27, 2008 | JVC LT-42X579 42 in. LCD TV
Troubleshooting Toshiba Satellite P205-S6267
is the laptop getting extremely hot on the bottom.
Could be thermal shut down (keeps the cpu from meltdown temperatures)
Robert
Aug 18, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Printer will not respond
Canon S330 Turn off printer
Hold down Resume button and press Power button.
Keep holding down Power button and let Resume button go.
Press Resume button 2 times then let BOTH buttons go.
Green lights will flash and then stop blinking.
When green lights are solid, press the Resume button 4 times.
Press the Power button and the printer should turn off, if not, press the Power button once more.
Your printer should respond as normal
Jul 22, 2008 | Canon S 330 InkJet Printer
Phone won't turn on
You may need a new battery. Also, hold the power button in for at least 10 seconds before letting go. The RAZR has a bad habit of not completely turning on unless you hold it in long enough.
Nov 30, 2007 | Motorola Mobility RAZR V3
Powered off
Plug it in and charge the battery. You should be able to turn it on while it is charging by pressing the power button. If it doesn't respond right away try holding down the power button until it turns on (well, at least 10 seconds or so). It is possible that the battery lost it's charge completely, but that's unlikely unless you have run it dry multiple times.
Jun 19, 2007 | Samsung SPH-a660/VI660
Samsung SGH-d807 Cellular Phone Logo
50 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
