Question about Hunter Fan Company 5/1/1 Programmable Thermostat
T-stat copatbility I have a wall fernace with a honeywell P107202 valve (not shore on the number) and i want to put a hunter t-stat model:B01-0603-HUNB01101L08 will it work. with out cousing any damage to my furnace
  • 52 Answers
On the back of most t-stats is a dip switch that is marked E or G that is changes the stat to work with either Electric heat or Gas heat just make sure you set it for the appropriate type of heat source your house has. Usually when we speak of Furnaces we are talking about gas, if that is so just change the switch to G. Good luck
Posted on Jan 29, 2008
Hunter 44860 touchscreen thermostat- My thermostat displays "LO". My wife said she played with it and can't fix it. He heat won't shut off! I thought it was the batteries so I replaced them. I noticed...
I suggest to everyone NEVER to buy a cheap thermostat from any box store regardless of brand. Always go with Honeywell or White Rodgers high end stats and DO NOT lose their booklets.
Feb 19, 2015 | Heating & Cooling
Changed honeywell T8400C 1024 to Hunter 44760, I have five wires white, red, yelliow, green, blue. Hunter Thermostat reads "NO A/C Power.
On the t-stat and the furnace make sure the wires are hooked like this...
Red to R
White to W
Green to G
Yellow to Y
Blue to C
then it should work..
Thermostat Wiring and Terminal Designations
heatman101
Jun 12, 2011 | Heating & Cooling
I HAVE A HONEYWELL THERMOSTAT THAT HAS BROKEN. IT HAS 7 WIRES. G-GREEN C-BLUE R-RED Y-YELLOW L-BLACK W2/E-WHITE O-ORANGE ITS ELECTRIC WITH NO BATTERY. I BROUGHT A HUNTER THERMOSTAT WITH BATTERY. ALL IT HAS...
Shut power off to Air Handler first before hooking up the thermostat..... Looks like the Hunter Thermostat does not have a Common Terminal...... Is it a Heat Pump thermostat???? I am not a big Fan of Hunter Thermostats they do not have the features that Honeywell thermostats have.
Back to your Question:
G to G ; R to Rc&Rh : O to Y/O; White Wire to W/B; Y to Y1;
L-Black is not used it was for a service lite
C-Blue will not be used it was the common wire
With the Hunter Stat you will not have an emergercy heat option
May 24, 2011 | Heating & Cooling
Cannot get Hunter stat 44155c that is connected to a Rheem 1210b to shut off after the stat reaches the set temp. How is an original 7 wire connected to the Hunter stat?
y is to condensor contactor wire
c is common
r is power
w/w1 heat strips
o/b reversing valve
e/w2/aux heat strip also
g is blower
For a rheem unit, make sure reversing vavle is set for "B" not O.
Blower may run for up to 120 seconds after shut off. My experience with hunter stats are not good (even out of box). Recommend honeywell tsat.
Apr 05, 2011 | Heating & Cooling
Honeywell thermostat manual
The model number is going to be on the thermostat. It is not unusual for the number to be on the back of the stat, meaning you may have to take it off the wall. It could also be found betweenthe base ans the stat.
Once you have the model number googel "Honeywell XXX" with XXX being the stat model number. If you can't find the stat, you can go to the Honeywell web site and do a search, matching your stat, by the pictures and functions. It is a bit tedious, but it works.
Jul 22, 2010 | Honeywell Programmable Thermostat Heater
Do i need a low voltage transfomer to hook up my
what kind of thermostat to you have, did you purchase the thermostat with the unit are you upgrading to a electronic thermostat, If you are using the mechanical thermostat that comes with the unit you will not need a thermostat. please see the link below and page 11
http://www.wfc-fc.com/pdf/Monterey_Top_Vent_IOM.pdf
Jan 17, 2010 | Honeywell Programmable Thermostat Heater
Programmable thermostat
Basically, your going to press either of the arrows until it flashes, or about 1 second.
Then you set the temperature you desire and then press and hold the HOLD button until HOLD is displayed in the display.
Congrats, your on a permanent hold.
Then your next step would be to go get a real thermostat, install it on the wall, and then throw that piece of **** Hunter out the window as hard as you can.
The biggest problem with the Hunter stats is that they are cheap. On top of that, the programmable stats have a factory set program that cannot be simply deleted. Its always there, no matter what you do. And it makes for hassles when it goes back to factory settings and you either have to painstakingly re-program it or deal with the factory settings.
Here is a link to the Hunter manual.
http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/43153.pdf
I would recommend to you the Honeywell line-up. The Visionpro 8000 series is a very nice and user friendly thermostat. Its the same one I have on my wall. Very easy to use and understand. Its touchscreen and the screen can be locked to avoid unwanted use of the system.
Jan 14, 2010 | Heating & Cooling
I have a Red, White, Blue and Green wire , need to wire a Hunter B01 MOdel or 44110 Thermostat has the following ports available G, RC, RH (RC & RH Have a jumper between them), Y/O, W/B, Y/1
From what you describe you have a heat only system with no AC. If that is so, then you would wire it as follows.
Red wire = RC (leave the jumper in place)
Green wire = G
White wire = W/B
Blue wire = is unused because the thermostat is battery powered and does not require a common wire.
I reccomend you consider not using the Hunter T-stat. They are so extremely problem prone and unreliable. You will be much better off with a Honeywell or White Rodgers T-stat.
You will also need to program the Hunter T-stat for your system per the instructions.
Oct 04, 2009 | Heating & Cooling
Replacing 2 honeywell thermostats with Hunter.
The hunter uses batteries and a ram chip to "remember" how you set it, the common is not needed with the Hunter. Some thermostats used the 24 volts of the thermostat circuit for powering up displays or for internal functions such as relays etc. Modern stats consume such a small amount of juice it is not typically required these days.
Aug 21, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter 44100A programmable thermostat
Yes you will need the orange (o) wire for the reversing valve in your heat pump. T-stat color code is red (r) for 24v power from transformer. Blue (x or c) is the common or the other 24v power from transformer and this will power your programmable t-stat. Orange is for the reversing valve that will switch your heat pump from cooling and heating. Green (g) controls your inside blower. Yellow (y) brings on your outside unit. White is your backup heat.
Sep 28, 2008 | Heating & Cooling
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
226 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
