Sony KP-61V85 61 in. Rear Projection Television
Problem for Sony KP-61V85 61 in. Rear Projection Television
Sony KP-61V85 convergence problem
By Duke - usenet poster
I just recieved a new 61" Sony projection, and am having a real problem with convergence.  The "FlashFocus" / auto-convergence feature converges the tubes, but does not saved the converged setting (and believe me, the setting that came from the factory is horrible).
Since the consumer menu system does not allow for manual convergence, I assume using the service menu is the only way to accomplish this (other suggestions would be appreciated).
Does anyone know where I could obtain a service manual for this TV (with the convergence commands, etc.).
THANK YOU!
Solution #1
posted on Jun 16, 2009
Not Rated)
ekikm_m_i
Rank: Apprentice
Rating: 0%, 0 votes
cambia stk 392 150 y ajusta convergencia en servisce mode ( apagada la tv y con el control remoto. en esta secuencia: display, 5, v+ y power) con el remoto apretar el numero 4 hasta llegar a unas xxxxxx de color blanco, apretar varias veces el numer 6 para entrar a la cuadricula despes el 9, con el 3 cambias de color, cuando ajustes todo: gravar con mute y enter. nota: tienes que ajustar antena y componente aparte en varios formatos de vide o puedes ajustar todo copiando todo con esta funcion: display y enter. espero que les aya ayudado atte: mike mata
Was this helpful?
Yes
No
Solution #2
posted on Aug 09, 2005
Not Rated)
Beresford
Rank: Apprentice
Rating: 0%, 0 votes
You should call an authorized Sony service tech out to properly do the
convergence, unless you bought it at Sears in which case it has ZERO
Sony warranty.
Even if you had the service manual you would not be able to do the
convergence adjustments as they come in a separate adjustment manual,
BUT, you also need the Sony school training manual and have attended
Sony's full day training on just doing the convergence properly on these
tv sets.
I STRONGLY recommend you either have a trained tech do it under
warranty, or exchange it for one that might have been setup better at
the factory.
If you have any large speakers near the bottom of the tv set with large
magnets, these could very easily be throwing off the convergence a lot.
Magnets do not cause purity problems on RPTV sets like on a direct view
tube, but they still bend the beams causing convergence problems.
David
Was this helpful?
Yes
No
Solution #3
Not Rated)
2Pansy
Rank: Apprentice
Rating: 0%, 0 votes
Standard Electronics 1-800-333-1519
  "Geoff Clark_H" <geo @optonline.net> wrote in message   I just recieved a new 61" Sony projection, and am having a real problem with convergence.  The "FlashFocus" / auto-convergence feature converges the tubes, but does not saved the converged setting (and believe me, the setting that came from the factory is horrible).
  THANK YOU!
Was this helpful?
Yes
No
Popular Solutions for Sony KP-61V85 61 in. Rear
Questions and Unsolved Problems for Sony KP-61V85 61 in. Rear
Do you recommend Sony KP-61V85 61 in. Rear Projection Television?
Answer
Answer
I have a Sony KP-61V85 and today I went to turn it on and it would not turn on. Unplugged it and... (More)
Answer
I have horizontal lines that move from top to bottom of the screen. Almost like radio freq.... (More)
Answer
are sony big screen went out on us all it does is the red light that comes on when we turn it on... (More)
Answer
when the power plug is put in outlet the red light comes on and stays on and i cannot turn power on
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KP-61V85 61 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 821
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
