Question about GE 7-5295 Undercounter DC /Radio Combo - WHITE CD Player
Tone adjustment Is there a tone adjustment for this unit? I can't seem to figure it out and the tone is very poor.
  • 70 Answers
If it have no tone control simply add a tone control accross the volume controll and add two capacitors on both end of the tone controll as shown in figure
Posted on Jan 16, 2008
6ya staff
SOURCE:
I have Kenwood 106vr receiver, still working but lost remote control. Is there other way to adjust the BASS & TREBLE directly in the unit?
Hello
Not possible to adjust the tone without the remote.
if you have the possibility for a universal remote like "Logitech" remotes its Recommended for such cases, that will be easier for you to control the the AVR system.
Jun 13, 2016 | Kenwood Audio Players & Recorders
How do I regulate tone -- would like higher and clearer pitch on voices
You don't have tone regulation on CD players, you need to connect it to an amplifier .
Jul 21, 2008 | RCA Personal MP3/CD Player
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
How to adjust tone on sony tv without obvious tone controls
If this TV has a working remote, and unless it is older than dirt, you should be able to access the audio adjustments by punching the menu or set-up button and selection audio - from which you should see a graphic equalizer of some description. Then adjust your bass there and return to viewing by again hitting the menu button. It's doubtful you can do any of that, or even that you should have to, from the set front.
Nov 09, 2017 | Sony Televison & Video
How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Jun 30, 2009 | Yamaha RX-V657 Receiver
Switching from pulse to tone dialing (there is no switch on the base unit)
hold the select button down a few seconds until you'll see a 'tn' on the readout. this sets it to tone. hold it down again and it will set back to 'Pu' for pulse. i figured this out by accident. the losers at vtech never answered my question.
Oct 25, 2008 | Vtech 2467 Cordless Phone
Ring tone thingy
Setting and Transmitting Call Tones
Your radio can transmit different call tones to other radios in your group so you can alert them that you want to talk.
To set a call tone:
1. With the radio on, press MENU 3 times. The current call tone setting flashes and displays.
2. Press + or - to change and hear the call tone.
3. Press MENU or PTT to set the new call tone or turn feature off.
http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf
Sep 07, 2008 | Motorola Talkabout T5420 (14 Channels)...
Pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Mar 16, 2008 | Lands Phones
Reciver need to adjust bass or trebel
Hi Brent
hhmmmm, I searched through the manual to find this info for you. It appears that the tone adjustments are initiated by the "tone" button on the REMOTE. I could not find any reference to there being a button to do same on the front of the unit. Odd, but there you go.
  1. Use the tone key(on remote) to get "tone" up on the front of the unit.
  2. Then using the multi up-down keys, turn the "tone on".
  3. Once you have got to here, use the tone key to select "bass" or " treble"
  4. Using the multi up down keys, adjust the tone controls to your liking with the multi up down keys
you can download the manual from
http://www.retrevo.com/s/Kenwood-VR-60RS-Receivers-review-manual/id/480bh239/t/1-2/
Just enter your email address and away you go. Good Luck. A "FixYa" rating would be great for my time to research this for you.
regards
Graeme
Feb 16, 2008 | Audio Players & Recorders
GE 7-5295 Undercounter DC /Radio Combo - WHITE CD Player Logo
91 people viewed this question
Top GE Audio Players & Recorders Experts
Ekse
Racki123
Level 1 Expert
Rob Hill
Rob Hill
Are you a GE Audio Player and Recorder Expert? Answer questions, earn points and help others
