Question about Rode NT-2000 Professional Microphone
Microphone Problems I am not able to get my mic to work in 2 or more ventrilo servers or when I am in any type of game(using a mic) and vent at the same time. Basically I would like to know if I can change the settings on my comp to allow me to have 2 or more diff outputs.
0 characters
1 Points
What is the best way to run the mic on desktop
Your condensor mic requires special electrical handling usually reserved for proffesional audio equipment, not a PC. You will need two pieces of equipment, a short XLR cable and an adapter cable.
1) Behringer PS400 Ultra-Compact Phantom Power Supply.
This will supply the mic with necessary Phantom Power.
2) Rapco Horizon ISOBLOX Transformer Isolation 1:1 BLOX Device
This will isolate the Phantom Power from your computer, allowing it to work as necessary.
The adaptor connector cable you need will be a female XLR (with pins 1 and 3 shorted, pin 2 hot), through a cable connect to a 1/8" mini plug. They connect in that order with a short XLR cable between 1) and 2). .
Aug 23, 2012 | CAD Microphones GXL2200 Professional...
I have 2 samson mics one usb the other audio the audo mic works well with my m box because i use protools but the usb mic does not how can i use both mics together
the usb mic can't be used with the m box, it can be used as a source in your audio software however. When you assign your audio sources look for USB Codec in the choices. I have a USB mic and it works great
Mar 12, 2011 | Samson C01U - USB Studio Condenser...
I just today bought a Samson R21S microphone, and I plugged it into my laptop via the laptops microphone jack, and immediately had problems. It cuts off my voice in mid sentence, it wont get half of my...
Not really the mic's fault - just incompatible.
Your Samson mic is a "dynamic" type and the laptop is expecting a "condensor" type.
You could put the mic through a preamp first but easier to exchange for a more suitable type.
Hope this helps.
Jul 09, 2010 | Samson R21S Microphone
The other day i was using my mic and it stopped working. and know i have no idea,and i went to your page and followed instructions from a post and now i can't hear anything. So the problem is that i can't...
turn up the volume first.
does it make a click noise out the speakers or show a reading on your mix etc when you switch it on.
if it doesnt then the switch could have gone,other than that i've only ever repaired 2 mics before & they both had doggie switches so i carn't really say more than that. sorry mate.
Aug 09, 2009 | Portacom Porta-Com COM-60FC 6 Headset...
Microphone works when tested in Windows XP but stops working
Sounds like the game has it's own i/o (input/output) settings. Go to preferences or settings in the game menu (may be under options) and select your input as this mic and not the internal microphone that it has probably defaulted to. Make sure you have your mic plugged in before you start up the game though.
Jul 27, 2009 | Logitech USB Desktop Consumer Microphone
Headet and desktop microphone problem.
first check if you have the right drivers on your computer for your audio, if you have audio like mine go to realtek audio manager it should be right beside the clock, then click on the top right corner it says device advanced settings it opens another box that gives you options for recording like tie up same type of input jacks, ie. line-in or microphone,as an input device. and it has another one separate all input jacks as independent input devices you could try one of those if you have realtek audio manager theres other options to that might help and if you dont have that go to recording devices and see if your mic is working properly and if its set to default device
Apr 25, 2009 | Logitech USB Desktop Consumer Microphone
Try and redownload the driver.
heres a site youd need to find it if you dont have the cd,en?selectedcrid=408&selectedcid=221#
Jul 24, 2008 | Logitech USB Desktop Consumer Microphone
Eternal static
microphone earth shield may be broken.check ur power supply current filters (capacitoror regulator ic,other regulator circuits). check and remove the interference near to the mic (mobile charger , switch mode power supplies)
Feb 12, 2008 | Microphones
Rode NT-2000 Professional Microphone Logo
50 people viewed this question
Top Rode Microphones Experts
Mike Cairns
Mike Cairns
Jay Plesset
Tom Chichester
Are you a Rode Microphone Expert? Answer questions, earn points and help others
