Question about Frigidaire GLTF2940ES Front Load Washer
No water in ice maker or drinking water thru door
I have an older washer 6- 7 yrs old The tub filled with water but did not agitate or spin
    Problem Solver:
  • 35 Answers
Is this a fridge/freezer or a washing machine? ;-) (check title)
if it's a wm, and the motor runs, then probably a broken/lose drive belt, or clutch slip. Possibly brake not releasing, faulty switch or relay. Really need more precise description of symptoms before can give more precise help.
Posted on Jan 16, 2008
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
Why am I not getting any water in the ice maker but do have water through the door to drink
Check your fill tube to see if it is frozen first. Check to see the bail arm is not up. check valve operation some ice makers will allow you to do this manually.
Apr 15, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
New Hotpoint washer purchased Nov.2010.....Problem 1. Fills, agitates and "drains" NO SPINNING this cycle. #2. Rinse fills with ONLY ABOUT 6-7 gallons of water, agitates about 10-15 seconds then...
may have a bad pressure fill switch and thats the reason not filling all the way have you tried on different load sizes... if this is a top load unit need to check the fill hose that goes from side of tub to pressure switch in console make sure has no cracks or kinks in it... what happens is water fills tub and then pressure from tub water goes up clear plastic hose to pressure switch to tell it to advance to next cycle... may be your culprit. and causing other problems... as far as clothes tearing beware hotpoint had a issue with there tubs coming loose the nut that holds down tub will back off causing exess movement and will allow clothes to get under unit... this unit should be still under mfd warranty... call g.e and get a servicer out there to look at it.. at worst you may have to pay a service charge but parts should be covered along with labor.... good luck pleae vote./...
servicer for 18 yrs heating /air / and all major appliances g.e authorized and lg. authorized for 8 years
Jan 03, 2011 | Hotpoint Washing Machines
Washer will fill and drain but not agitate
Check the lid switch if it is a top loader.
Nov 04, 2009 | GE Washing Machines
GE top load washer does not agitate or spin.
sounds like a bad lid switch how old is it?
Dec 29, 2008 | Washing Machines
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Sep 02, 2007 | Washing Machines
Frigidaire GLTF2940ES Front Load Washer Logo
37 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
