Question about LG RU-44SZ51D 44" Rear Projection HDTV-Ready Television
Crackling Sound There is a crackling sound coming from the front of the TV. I suspect this is coming from the speakers. I t sounds like the crackling from a fireplace. It started in the middle of a program and has not let up. Any suggestions?
  • ice2144 Jul 28, 2008
    I have a Samsung 32 inch flat screen which has been making crackling/snapping noices coming from the speakers. Can anyone suggest a way to get this to stop ??
    New Friend:
Decided to investigate crackling in front left spkr of my Samsung tv. Turned out to be main board vibrating. I added bushings behind main board mounting screws- crackling gone!
Posted on Dec 03, 2017
I just bought a samsung 550 50 inch plasma and hear the crackling noise from the TV. The reciever is using hdmi out to the TV. When I turn the TV on after it cools down I hear this noise then I turn the TV off and then on and it goes away. I just bought the TV and Bestbuy will be replacing it this week. I hope that solves the problem.
Posted on Oct 16, 2008
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Posted on Jun 05, 2008
Panasonic sa-pt860 speakers crackling
Panasonic SC PT860 Manuals
The above link is the owner's manual - it may help.
Here are some other ideas:
Try to find out if the crackling sound is coming from all speakers or just one - you may just have one bad speaker.
If the crackling happens at high volume settings, you may be overdriving the system - you'll just have to turn it down!
Try turning down the bass or the subwoofer level.
Is the crackling present with all sources (TV, cable, DVD, bluetooth)?
Sep 22, 2016 | Panasonic Audio Players & Recorders
Protron tv crackling sound
The speakers that are inside your tv are damaged and needs to be replaced, after you replace your speakers, the Sound will return at the correct factory settings from which you received your tv..
Feb 10, 2013 | Protron PLTV-37 37 in. LCD Television
I have a crackling speaker on the left port of the bass box
The crackling sound on the left port of the bass box, indicates vibrating foreign matters inside it. Just open the box and clear it up. Put the sounds on. Listen if the crackling sound is audible. If the result is ok, then, close the box, and everything is alright..
However, if the result is otherwise, then, it is due to a defective speaker that needs to be replaced.
Nov 21, 2009 | Creative Labs Sound Blaster Live! 5.1...
Sound fluxuates,crackling sound samsungTX-R3079WH sound goes up and down automaticly
If the sound FLUCTUATES up & down, try turning off the AutoVolume in the sound menu. You didn't say if it's one or all speakers crackling. Crackling is either a speaker or circuitry issue. Adjust the balance away from the speaker that crackles, if it stops, that speaker is probably "fried". If it still crackles, I'd turn off the speakers and run the sound thru a stereo for the quick, cheap fix. My Samsung (10+ years old to be fair) crackles due to a circuit issue but if I SMACK the left side speaker (behind which is the sound board and side panel connectors) it stops for a while. Maddening. I think I broke it squeezing it into the furniture it's in, pressing on the protruding RCA plugs. Dumb design.
Aug 15, 2009 | Samsung SlimFit TX-S2783 TV
Continuous crackling from TV speakers
I'm sure you have figured this one out. TV itself is causing the problems.
The circuit board that produces the audio signal seems to be the problem.
Before you call the repairman, go to the web site Shopjimmy.com just to get an idea of what the parts will cost. That way he doesn't rip you off.
I hope I answered your question correctly. Please rate me. :)
Feb 26, 2009 | Samsung LN-T3253H 32 in. LCD Television
Crackling Sound
Not sure what model but there is a coil on some LG LCDs that needs to be replaced on the SMPS.
Jul 01, 2008 | LG 42LB5D 42 in. LCD Television
TV is crackling
From the speakers or from the inside of the unit. On all modes, eg. normal tv + digibox/scart input???
Apr 05, 2008 | Televison & Video
Crackling Sound from Speakers
check audio cables wiggle them around if no difference in sound check other inputs if they all crackle call for service it sould be under warranty probably in the speakers or the input board
Oct 23, 2007 | LG 50PX4DR 50 in. Plasma TV
Snap, crackle sound from Sanyo TV
It sounds to me as if possibly ya Main IC Amp Chip & OR the Output Capacitors are failing... Sometimes it is a sign of a power supply on it's way out... Either way it's time for a repair shop quote. Either that or it may be the speakers crossovers... to check this, if you can, try another set of speaker... see if problem is still there. If it IS, then it IS most probably as I said above.. If NOT then it may be one or both of the "Crossover Network" in each speaker...
Sep 01, 2007 | Sanyo AVM-3659S 36" TV
Crackling sound when changing channels
Check the connections to the speaker and the receiver. Had a loose connection once that did the same thing.
Apr 15, 2007 | Definitive BP7001SC Main / Stereo Speaker
Open Questions:
LG RU-44SZ51D 44" Rear Projection HDTV-Ready Television Logo
1,331 people viewed this question
