Question about Olympus P 400 Thermal Printer
Blurry photos When I try to print several photos that have been combined using photoshop all of the photos are blurry.  The resolution is 180 and the photo only has one layer.  The photo is a jpg.
  • tony124 Jan 16, 2008
    Blurry might not be an accurate description.  It is as if the colors aren't aligned during the print process.
  • 29 Answers
Bump up the resolution to 300 and look in your printer settings
Posted on Jan 16, 2008
  • Christina ODonnell
    Christina ODonnell Jan 16, 2008
    Sorry onnly other thing I can think of is to run the realign cartridges.
Picture Size to Large?
This may not be the solution; however, please obtain a larger capacity memory card.
A 2GB card will give you several hundred photos. Cost is less than $10.
You really should not lower the resolution. you will lose detail that you may want in the future (really). (4GB card will hold over 999 pictures - $15)
If you must lower the resolution, press "Menu" and use the arrows to move the highlight bar to "resolution" ... change it to a lower number like 6MP. keep the "FINE" setting in place (if your model has that setting) or maybe "BEST".
Do not use "RAW" - (very large pix).
Hope this helps!
Sep 03, 2009 | Canon Rebel XT / EOS 350D Digital Camera
PRINT IS BLURRY
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions. PSC 1600 User guide: http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 11, 2009 | HP PSC 1600 InkJet Printer
How do I increase the dpi on TZ5
Hi - When talking about resolution in digital photography there are two main meanings.
One is the "pixel count resolution" and the other "embedded resolution". So for example your camera could record 2272*1704 as the actual pixel count resolution and set 72 as the embedded resolution that tells other software (for example photoshop) what the intended use of the picture will be. 72 ppi is the default for web pictures. You can change this in photoshop by going to the "Image" tab & select image size. The window that opens will show you the pixel dimensions i.e. pixel count resolution and the document size & resolution 72. You just change it in your software to 300 for printing. In Photoshop you can change the default to 300 by going "edit", "preferences", "units & rulers" and setting the values for "new document preset resolutions".
So for your camera the embedded resolution is 180 which you can only change in your PC software.
This is a complex subject, I recommend looking at the following web page:
http://www.fotofinish.com/resources/centers/photo/resolution.htm
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 13, 2008 | Panasonic Lumix DMC-FZ5 Digital Camera
Changing the resolution on my camera before i go to photoshop
using the RAW setting will give a higher quality photo, the other formats compress to jpeg causing you to loose some of the original photo information. the ZoomBrowser EX program allows you to edit the RAW image, I recommend getting the large prints done at Kinkos or some place like that. I've gotten poster size prints done that look very clear. Use a tripod to combat camera shake, it is very apperent at that size of print. Also a low ISO to help reduce noise.
Sep 04, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Image qulaity problem in fujifilm finepix fd50
It sounds like the resolution on the monitor may be set incorrectly in Photoshop. Try a different monitor setting. Twelve megapixels may result in your monitor "seeing" so many pixels it tries to ignore the excess ones, resulting in an image that looks poor on your monitor. If you order one print, that may give you an idea of the true printed quality without spending a lot of money on a bunch of bad prints. The F50 is truly an excellent camera and gives super images, from my experience.
Mar 02, 2008 | Cameras
Poor printing resolution...?!
You can select whatever resolution you want to print at on your Print(er) Setup.
If your Printer is automatically selecting a 72DPI to print at, you may be trying to print a 10X12 pic size or larger by default due to pic file size created when pic was taken in camera with full 7Meg resolution.
Use photo software to proper size the print before printing. If you want a print larger than 5X7, keep in mind the TZ3 begins to have recognizable noise, reduced resolution due to noise, especially in low light indoor or evening/nite outside shots. You can use photo software to improve and size them before printing. Windows Vista has a built-in photoshop type program. Else, I believe your camera comes with one on disk.
Also, read your manual regarding shooting with this camera.
Nov 09, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Canon Rebel xti vs Photoshop!
What you are seeing is the difference between "pixel count resolution" and "embedded resolution". So in your example 2272*1704 is the actual pixel count resolution as recorded by the camera & 72 is the embedded resolution that tells the software (in this case photoshop) what the intended use of the picture will be. 72 ppi is the default for web pictures. You can change this in photoshop by going to the "Image" tab & select image size. The window that opens will show you the pixel dimensions i.e. pixel count resolution and the document size & resolution 72. You just change it to 300 for printing. You can change the default to 300 by going "edit", "preferences", "units & rulers" and setting the values for "new document preset resolutions". This is a complex subject, I recommend looking at the following web page: http://www.fotofinish.com/resources/centers/photo/resolution.htm Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 15, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Minolta Dimage S414 Problem with resulution
Aug 08, 2007 | Konica Minolta DiMAGE S414 Digital Camera
Confused about Resolution Sony DSC-T7
2.2 MB is the size of the file on your hard disk. Being a .jpg, it is a compressed file. The file size does not reflect the size of the image stored inside the .jpg. Yes, the size sounds about right. It will increase or decrease depending on how much detail there is in the picture. If, for instance, your picture is made up of nothing but uninterrupted blue sky, the disk file will be quite small - as the .jpg does not need to store much information (the more repetitive information, the smaller the file). On the other hand, if your photo consists entirely of nothing but blades of grass, the disk file will be comparatively large. When you see "DPI", that refers to print resolution. So, since you're not printing, but rather, viewing onscreen, Photoshop "assumes" a convenient "screen resolution", as though you printed on the screen (don't ask!). If you look at the other settings, you'll note that Photoshop also thinks your photo is 36" wide!!! You adjust the DPI (or photoshop will) when you print. Till then, it doesn't mean much. Let me give you an idea of your image's possible DPIs. Assume you really want to print a 36" photo: 2592/36" = 72 DPI If you make the picture 12" wide: 2592/12" = 216DPI At 10": 2592/10" = 259.2 DPI At 8" 2592/8" = 324 DPI How do you get my photos above 200 DPI? By printing the picture small enough, less than 12.96" on the wider side. See calculations above. The resolution at which you shot the image (2592X1944), will not cause blurriness. As for the cause? There could be any number. Was the subject moving? Were you? Did you shake the camera while shooting? Is your shutter speed too slow? Should you have been using flash? Is the camera autofocusing correctly? Are you waiting for the autofocus to lock before pushing the shutter the rest of the way? Etc. Hope this helps somewhat...
Sep 12, 2005 | Sony DSC-T7 Digital Camera
When I printed the photos none of them was even close to film-based photos
Try using a good program like Photoshop and when you adjust for printing...make sure you DO NOT subsample the image so it can fit on a 4x6 photo paper page. What I mean by that, is in fact reduce the image to fit on such a small page but do not kill the resolution.... In Photoshop, you would open up Image Size under the Image menu and turn uncheck resample image...as you adjust for paper size...you will notice that your resolution stays intact on the top of the window. I assume that is your problem since the 2500 is highres and should give you fantastic results in a 4x6 format.....
Sep 06, 2005 | Olympus Camedia C-2500L Digital Camera
Olympus P 400 Thermal Printer Logo
183 people viewed this question
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
