Question about Honeywell Programmable Thermostat Heater
My Heating system
I need help with my Honeywell Heating system because it just stop working. Even though i switch it OFF and then back ON yet it's not heating up.
  • 1,420 Answers
Can you provide me with a make of the furnace and a model number if possible. They will be found on the heating system cabinet inside the unit, not on the thermostat.
Posted on Jan 16, 2008
I have a honeywell smart thermostat and it stopped working and I have no air conditioner
When did it last work? The first thing I would do is turn off the breaker that powers the A/C system. If it's a central system there are probably two 2-pole breakers (outside unit and air handler) turn them off, wait a few minutes and turn them back on. Let the system re-set (compressor time-out is at least 5 minutes after turning it back on. After the system is reset, see if your thermostat is working correctly and if not, try this link for an overview of Honeywell troubleshooting. Honeywell Thermostat Troubleshooting Six Step Guide
Jun 24, 2018 | Honeywell Heating & Cooling
How do I fix central heating
The first thing you need to substantiate is the fact that there is enough water in the system. It will be a closed loop system requiring approximately 10 psi/ floor. (Only a rule of thumb). Usually when one protion of the system works and the other does not, it is an issue of water quantity available to circulate through the combination of loops. If you have to add water, you will probably have to purge air from the highest points in the system. Even if there is an "Airtrol" fitted in the bottom of the expansion tank, bleeding the high points will eliminate air quicker.
The hot water portion of the loop should only be going through a heat exchanger that transfers the loop temp to the domestic water circuit and the three way valve is probably a 'mixing valve' utilized to maintain a certain loop temperature on the primary loop.
Dec 01, 2014 | Honeywell Heating & Cooling
When there is a fault with the back to base security system it knocks out the heating/cooling control panel, even though now I have 2 control panels - 1 for heating 1 for cooling.How can the system be
this has appeared under truck and cars try the correct heading to post this question in please and perhaps someone will see it then and not a old washed mechanic like myself
Dec 30, 2011 | Cars & Trucks
My central heating keeps coming on constantlly even though my honeywell programmer is switched off what can i do
Your unit not responding the command from your thermostat. Check and replace sensor OFindoor PCB
Dec 24, 2010 | Honeywell Heating & Cooling
My honeywell Thermostat reaches the heating temp. but the fan will not stop running.And yes the fan is set to auto.It just keeps running and running and running.It stays the same temp but will not shut off...
I want to give a simple explanation before I go any further. On the heating side of a unit even though tthe temp has satisfied the thermostat, the fan will run until it cools down the plenum where the air flows from the air handler. There is a bimetal switch called a fan limit that operates the blower when the plenum reaches the temp set on the fan limit switch. Now if your fan keeps running even after the plenum chamber has cooled down, then you could have a fan limit switch that is stuck in the run position and must be replaced in order to correct the problem.
Dec 07, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
CM67ng will not turn heating off
Are you running some type of program on the tstat??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jul 06, 2017 | Honeywell Programmable Thermostat Heater
I replaced the battery to honeywell RTH230B. Heat won't turn on.
I followed a comment from a previous source and reversed the polarity of the batteries. I then flipped them back to the correct position and the flashing battery indicator went away and the thermostat functions correctly.
Feb 04, 2010 | Honeywell Programmable Thermostat Heater
Hot Water is not comming
REPLACE THE CIRCULATOR PUMP ON THE SYSTEM.IT IS NOT PUMPING THE WATER.
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
80 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
