Question about Sony PlayStation Portable (PSP) Console
Please wait Hi There, my daughters psp,says please wait... ,thank you help
    Problem Solver:
  • 6 Answers
Shut it off and take game out
Posted on Jan 16, 2008
6ya staff
SOURCE:
Laptop will not recognize psp
Hi lawolf77,
If your laptop wont recognize your PSP there might be a connection problem between the two. So you need to check what's causing the problem. There are several ways to check if PSP and your computer are properly connected, one good example is by checking the connectors and the device setting.
If you want to check some configuration on how to connect your PSP to your PC please try to follow these steps:
1. First, connect your PSP to your PC using a usb cable.
- please make sure both ends are properly intact.
2. Using the left and right directional button find "Setting", then scroll down or up to find the "USB CONNECTION".
3. USB CONNECTION will display after you pressed the x button.
4. Please wait until computer detects the USB connection. After that it will show the drive for your PSP. usually F: or G:
5. Click on your PSP drive letter.
6. Now you can determine if your PC recognizes the PSP, just access the root folder and try to put some files on it.
Hope it helps.
Thank you for using FixYa.
Feb 08, 2011 | Sony PlayStation Portable (PSP) Console
My psp wont connect to my PC? i tried almost everything please help!
Hi dominic_prig,
Based onyour concern, I suggest trying the following steps: 1. Before you plug it in make sure the PSPis in USB connect mode. --> Alsomake sure the Memory Stick PRO Duo has been formatted for PSP. 2. Connect the PSP to your PC with a USBcable. 3.Press the "home" button on the PSP --> atthe lower left of the screen you can see the home button. 4. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USBConnection" on the PSP. 5. Press the "X" button, your PSPshould display "USB Connection". 6. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 7. Click on the drive letter thatcorresponds to the PSP unit. Hope ithelps, Thank youfor using FixYa.
Jan 09, 2011 | Sony PlayStation Portable (PSP) Console
Cant off the psp go and still on screen is please wait..cant go to the menu
Greetings,
It seems like your Psp Go has gotten stuck on that screen. The only valid way to fix this is to either:
  • Wait for the Psp to Die. Just let is sit and it will run out of power eventually.
  • Pull the battery out of the Psp which will cut the power. Then place battery back in and turn on.
Thank you for using FixYa! =) If I helped, please give me a rating.
Dec 10, 2010 | Sony PSP (Piano Black)
PSP USB connection- screen reads please wait
there might be somthing wrong with the hard drive or with the usb
Mar 31, 2009 | Sony PlayStation Portable (PSP) Console
Psp region code
Unfortunatley you do need custom firmware to change the locked region code, official sony firmware does not support changing the region code.
Jan 15, 2009 | Sony PlayStation Portable (PSP) Console
DNS Error using my PSP Internet Connection!!!!
i can assist you with this.
Instructions
1 Take out the UMD disc from the back of the PSP if one is inserted. 2 Take out your memory card from the memory card reader if one is inserted. 3 Turn on your PSP. 4 Go to the "Settings" tab in the Cross Media Bar and select "System Settings." 5 Select "Restore Default Settings" and confirm that you wish to restore all settings to the factory defaults. 6 Restart your PSP. 7 Try connecting to the Internet again. If you still get the 80410A0b error, try connecting to another network. If you successfully establish a connection to another network, your router is at fault. If you cannot connect to the second network, your PSP's Wi-Fi card could be damaged and may need repairs. Tips & Warnings
Ensure that you are entering the Wi-Fi SSID and password correctly on the PSP. You can contact PlayStation Support (see Resources) to start a repair order if you PSP's Wi-Fi card is faulty. if you require further assistance please let me know and i will be glad to assist you. Thanks
Jan 05, 2009 | Sony PSP (Piano Black)
Power
Just unplug it and wait for the battery to die on its on. Then plug it back in and charge it again and see if it works.
May 24, 2008 | Sony PlayStation Portable (PSP) Console
Psp please wait
Try removing the memory card and any other accessory and turning it on then.
Feb 17, 2008 | Sony PlayStation Portable (PSP) Console
Update problem with psp
SOMETIMES TAKE THE BATTARY OUT AND PUTTING BACK IN AGAIN WORKS.
Dec 28, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
46 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
