Question about Sharp Viewcam VL-Z1U Mini DV Digital Camcorder
Error code "E007"
Is this camera worth fixing with this error code? It will not load a cassette at all.
  • Supercamera Jan 16, 2008
    I've tried this before and it provides no specific info regarding the error code.
    They are closed now. I have a feeling all Sharp will say is send it in for repair. Its probably not worth the $100+ though. I can't find any info on the web for the error code.
    Brigadier General:
  • 6,966 Answers
With the indulgence of C13295
E007 is not defined but previous dealings exhibits loading problems (which can be caused by dew or mechanical issues).
Four (4) things you can try:
1. Do a soft/col reset, remove the battery for a considerable time (hours);
2. Clean the loading/transport mechanism. Use a can of compressed air;
3. Tap, gently whack the unit or shake the cam side to side. (This is not a sound technical procedure but other owners have reported favorable result); and/or
4. Use a hair dryer set to lowest temp and do the tape tray/loading area. (Again, tis is not a sound technical procedure).
If none of the above would be corrective, perhaps your best bet would be to seek the services of a qualified camcorder technician/service center. It would also probably be worth your consideration of repair cost/downtime versus purchase of a new unit.
Hope that this be of additional help/idea. Pls post back how things turned up or should you need further information.
Good luck and kind regards.
Posted on Jan 16, 2008
  • Louie  Role
    Louie Role Jan 16, 2008
    for C13295
    I posted after your post "Hey man.....", and did not realize you posted anew. sorry for stepping in.
    Scholar:
  • 128 Answers
Try this out, this is the sharp support page. :) http://www.sharpusa.com/products/support/0,2309,,00.html
  • 4 more comments
  • Omair Chughtai
    Omair Chughtai Jan 16, 2008
    ok gimme a min mate
    lemme find another solution
  • Omair Chughtai
    here, i found there customer support teams number. 1-800-BE-SHARP (237-4277)
  • Omair Chughtai
    Hey man, sorry, but I got nothing left for you. My expertise is on video games. Maybe i can get another expert here for you so he can help you.... :)
  • Omair Chughtai
    Hey, i found some info on the error code. Error code E007 means there is moisture inside the Viewcam. Try taking the tape out, leaving the cassette compartment open for 2 hours to allow any condensation to evaporate. If it doesn't work, try taking it to bestbuy. They might be able to help.
  • Omair Chughtai
    You also want to try using a hairdryer to fix your problem
  • Omair Chughtai
    Thats alright Benimur, we are all just trying to help a customer fix his problem. There is no reason to aplogize.
How can i fix an E007 error code on CANON IR 2022?
Ther's aproblem with fixing unit. Usualy the fixing film has to be replaced
Jul 16, 2014 | Canon iR 2022i Printer
I have ir4570 error code e00007
It is my pleasure to guide you.
Your Canon iR 4570 All in One Printer Manual iR4570
User's Guide can be downloaded at http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
Look at Chapter 3 Troubleshooting
List of Error Messages ..3-6
List of Error Codes without Messages. . 3-6
You will find the list of error codes.
Also, http://servisfc.blogspot.com/2010/12/detecting-error-e007-for.html
gives the following;
QUOTE
Detecting Error E007 at canon copier iR2270, iR2870, iR3570, iR4570, iR3530.
As part of its protective mechanism, the machine checks for the following error conditions.
Error Code: E007
Detail: 0000
Sympton: The fixing film rotates in an abnormal way.
Description: The reading of the main thermistor is in excess of 100 deg C with the fixing motor in a locked state and in addition, the machine fails to detect the marker signal for 6 second.
UNQUOTE
Good luck and please post back that you are successful, giving thumbs up, or that I can be more helpful.
Jun 09, 2011 | Office Equipment & Supplies
My canon printer iR2018- error E007
E007 0000 Fixing film sensor failure
The fixing film sensor is faulty.
- Check the connector of the fixing film sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Nov 10, 2010 | Toshiba e-Studio162D Copier
Error E007 Canon Image runner 2020 Will not finish perinting a document with the above mentioned error
The error code E007 is a fixing film error code > it will have to be replaced to clear the code. That is if it a IR-2020, a IR-8500 does not have a fixing film.
Aug 20, 2010 | Canon imageRUNNER 8500 Copier
My iR2016 displays "system error E007, would you please help me repairing it?-
it error code means fuser unite problem please change fuser unite then solve your problem
Nov 20, 2009 | Canon PC-940 Black and White Copier
Cancorder not wrking-e007 error message
moisture in the cassette holder. Take out the cassette, leave the holder door open for a couple of hours in a dry, warm location, and it should work again.
Sep 12, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Canon IR2018 E007
E007 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
you need to call a canon technician to sort it out
Mar 22, 2009 | Toshiba e-Studio162D Copier
Error E007
 I  HAVE PROBLEM IN CANNON COPIER IR 2016, ERROR CODE E007. KINDLY HELP ME TO SOLVE THIS PROBLEM
Jan 21, 2009 | Office Equipment & Supplies
I have System error E007 problem in my Canon iR-2016 copier machine
System error e007 for canon copier ir2016j copier needs solution
May 23, 2008 | Sharp AR-M350N Copier
Sharp Viewcam VL-Z1U Mini DV Digital Camcorder Logo
263 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
