Question about HP Compaq nx5000 Notebook
When i plug in my hp nx 5000, they turn it on automatically even i didnt push the power button yet, and then before they boot up they read some sort of memory?
    Problem Solver:
  • 14 Answers
This is known as Wake on LAN. Basically, when the computer detects any network activity coming in, it will boot up. You can disable this in the BIOS. I would contact HP for help with that, though. The BIOS is a bit tricky and you can mess things up if you change the wrong thing.
Posted on Dec 01, 2009
HELLO , I HAVE A HP COMPAQ NX 5000 AND IT DIDN'T START. IT START VERY HARD, DID YOU CAN TELL ME WHAT'S THE PROBLEM ? THANKS A LOT !
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Feb 08, 2011 | HP Compaq nx5000 Notebook
My Pandigital 7' EReader won't turn on even when I charge it. I had it on playing a lullaby for my kids and now it won't turn on. Please help.
plug it in then push power+volume up for 30 seconds or until a message appears for 1 second easy to miss so dont blink until you see it then let go and press power button until it boots
Dec 19, 2010 | PANDIGITAL 7" Digital Photo Frame With...
My HP Compaq nx 6110 freezes afta the HP invent screen and doesnt go beyond that, and if i plug the adapter the system boots automatically but not beyond the HP invent screen. Please help.
Hello
Press and hold "CTRL," "ALT" and "Delete" at the same time. Wait and see if a prompt window loads. If one does you can select the program causing the crash and close it. This allows you to return to using the laptop.
Push and hold the power button until the system turns off. Typically, you need to hold the power button down for a few moments before the laptop shuts down.
Remove the power cord from the laptop if the power button does not turn the computer off. Occasionally this can occur, in which case you need to find an alternative way of cutting the power.
Flip the laptop over if the power button is not turning the computer off. Find the battery compartment on the bottom of the laptop and remove it from the computer. Momentarily the computer shuts down. Leave the battery out for a few moments.
Insert the battery back into the computer and press the power button. Shortly, the computer restarts and begins to load the operating system.
press F1 at start up to check the bios for power management settings as perhaps there is a conflict to the settings in Windows. Also I would check what is running in startup (msconfig) and leave nothing but essential antivirus and antispyware. I have seen Norton or MacAfee come up and cause this on several HP Laptops until I uninstalled every last bit of it
also ensure the laptop is in a roomy place a overheating could also be the cause
Dec 15, 2010 | HP Compaq nx6110 Notebook
We get a blinking green light response where the ''On'' button is on our Compac presario SR 1111 NX and cannot get the computer to turn on. Is this a battery problem of some sort? Can I fix it? The...
take out all the cables from the back of computer,press the power button for 1 min and then plug in only keyboard,mouse,monitor and power ,it will work
Feb 09, 2010 | Computers & Internet
Problem HP Compaq nx 7300 Yelllow light 8x
Have you had previous problems with your laptop power supply and battery? I have this same laptop and use it very regularly. I do have problems with battery life, but never actually powering on. I suspect the battery is not accepting a charge. My suggestion is to replace the battery and see how things go.
Oct 18, 2009 | HP Compaq nx7300 Notebook
Hp nx 5000 - memory problem
The memory modules are located at the bottom of the laptop under one of the panels.
The memory modules may be OK and may only need reseating. Then boot up the laptop to see if it works, if it doesn't work, the memory may be faulty, take it to a computer shop to get it tested.
Apr 07, 2009 | HP Compaq nx5000 Notebook
Have an acer 5000 which no longer turns on.
try it without the battery and see if that makes a difference. do any lights come on when its plugged in or when power buttons are pressed? how did you have the battery checked?
Mar 22, 2009 | Acer Aspire 5000 Notebook
Setting up a Compaq Presario 5000 tower and HP pavillion monitor
since your computer didnt recognize your monitor just add it manually ...if its an hp lcd screen hit the button above the power button on the monitor and it will auto adjust itself..if it still dont work go under control panel to monitors and add it.
Sep 01, 2008 | Compaq Presario 5000 PC Desktop
When you turn it on nothing happens
I just bought a lap top and no nothing about them it is a hp compaz nx 5000 I turned it on and the screen is still black don't know how and where to turn the monitor on
Apr 05, 2008 | E-Machines M5310 PC Notebook
HP Compaq nx5000 Notebook Logo
151 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
