Question about GoVideo Go Video DVD/VCR Combo
GO DVD+VCR DV2140
DVD door will not open. It reads DVD but won't play and won't eject either using the remote or the on machine eject button. Help
  • Tom Lindell Jan 16, 2008
    I disconnected for several hours and this did not work I banged on it and it did not work .So I was disconnecting everything to open the top and banged it against the table disconnecting the wires and it spit out the DVD. Just needed a bigger hammer and now I am motivated to buy a new DVD player and not a GO.
    Tom
    Brigadier General:
  • 6,966 Answers
If I may add to melnavz post.
Possibly two (2) reasons:
1. Firmware (software) glitch. Pls try do a reset, unplug the unit from the mains for a considerable time (hours) and thereafter try it again.
2. Hardware. The disc may not have seated itself properly and therefore causes a jam of some sort. You need to open the top cover and physical dislodged/remove/set the disc if this is the case. Alternately, it may be due to stuck up eject motor/gear or worn/cut belt or even dried up lubrication, dirt, dust. Still you need to open the unit. In some instances, giving it a gentle tap (or whack) on the side may aid in the eject process. Of course this is not a sound technical practice however, others have reported to have solved mechanical problems similar to this using the whack/tap method.
If you are not comfortable opening the unit or with the tap method, perhaps your best bet would be to seek the services of a qualified repair technician.
Hope this be of help/idea. Pls post back how things turned oout or should you need additional information.
Good luck and kind regards.
Posted on Jan 16, 2008
  • Louie  Role
    Louie Role Jan 19, 2008
    and Hi again,
    Glad to be of assistance and appreciate the rating.
    Cheers.
    Genius:
  • 1,226 Answers
It seem that your stuff had a big problem on it. It means that the optical lens is damage. However u can try fixing that by cleaning the optical lens inside the rom. and try examine all the buttons of the system maybe some are damage or freeze up.
GoVideo DV2140 DVD/VCR Combo Player/Recorder can i copy vhs to dvd on this product
The GoVideo DV2140 does not contain a DVD writer. It can only play DVDs and copy them to VHS tape.
I wish that I had better news for you. The manual is available at ManualsLib here: https://www.manualslib.com/manual/61649/Govideo-Dv2140.html .
Dec 21, 2016 | GoVideo DV2140 DVD Player/VCR
While playing the VHS the player switches from VCR to DVD in the middle of the movie multiple times. We ended up having to tape the DVD player closed because it would turn the player on in the middle of...
Hi, it sounds like either the eject button on the DVD player drawer has been damaged or the remote is in need of cleaning (I assume the remote to have an eject button too). you can remove the remote by removing a battery and seeing if the problem stops.
Best you remove the tape from the DVD drawer as this will not stop the DVD mechanism from trying to open the tray, bit like trying to constantly push against a locked door - you will cause damage if it hasn't already.
Aug 13, 2010 | Zenith XBV442 DVD Player/VCR
We have a GO DVD+VCR model No. DV2140. We cannot
If you are trying to play blue ray on this unit you are out of luck no amount of firmware will make it play something it is not capable of doing.
Aug 14, 2009 | Televison & Video
DV2140 DVD player door will not open.
Most manual overrides involved pressing and holding either the eject button or the power button on the machine itself (not the remote). Try those first.
If that doesn't work reply with the following info:
Will your system turn on/off?
Are you able to play the disk that's in the drawer?
Jul 09, 2009 | GoVideo DV2140 DVD Player/VCR
DVD DOOR AND VCR DOOR WILL NOT OPEN, DOES NOT EJECT TAPES OR DISK
I have had some luck in unplugging the machine for five or ten and then trying again. I have spent five to ten minutes trying to get the darn thing to spit out the disk and it refuses. Unplugging either gives me time to cool off or it helps the machine :)
Apr 30, 2009 | Panasonic PV-D4745S DVD Player/VCR
Dvd & vcr DV2140
TRY UNPLUGGING THE UNIT FOR A FEW MINUTES.SOMTIMES THIS WORKS.
Nov 01, 2008 | GoVideo Go Video DVD/VCR Combo
Remote code for go video model# dv2140 dvd/vcr combo
I have a universal remote from ComCast cabel and was able to get code 0591 to work for the Go Video DV2140. It's one of the same codes as the Zenith DVD player.
Dec 14, 2007 | GoVideo DV2140 DVD Player/VCR
Remote Buttons
Press the VCR button first then press open/close
Nov 22, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Turn off the unit, Unplug it. wait 30 seconds. plug it back in. Press the power button on the unit press source so that its on dvd and press eject
Aug 25, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Insignia DVD Player
Try hitting the "Lock" button on the remote. That solved the problem for us.
Dec 03, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
GoVideo Go Video DVD/VCR Combo Logo
55 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
