Question about HP OfficeJet 7410 All-In-One InkJet Printer
Repeated error message
Keep on getting error message replace ink cartridge on the right. Cartridge replaced twice with new cartridges and the same message.
  • stephy922 Jan 18, 2008
    I'm having the same problem. Hopefully someone might have a suggestion.
Very Simple, Probably...
Just remove the cartridge and see if the metal spring clip has broken away from the right wall. If it has, inspect the gold colored circuit board at the back of the cartridge bay...there is probably a hole or dent where the clip slammed into it.
If you have these symptoms, go to HP, and go to the chat support window, describe your problem, and they will send you a replacement printer.
It's exactly what I did.
Posted on Jan 23, 2008
6ya staff
SOURCE:
I have replaced black ink but printer keeps telling me to replace black ink cartridge
If the it's a remanufactured cartridge (not genuine), the printer will not detect the ink in the cartridge.
If it's genuine, you might want to give Lexmark's technical support a call to have the cartridge replaced.
May 05, 2012 | Lexmark X4650 InkJet Printer
I have a dell all in one printer 944. When I turn it on it keeps sending the message, "change ink cartridge" I have changed the cartridge twice and message remains the same. Is it broken?
Are you using Dell Series 5 ink cartridges?
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message, please read bleow.
Black cartridge = black side(left side) Color cartridge = Color side(right side)
Photo Cartridge = Black side(left side) Color cartridge = Color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It is also possible to get a new ink cartridge with a bad sensor. Please take it to the place of purchase for a refund or a replacement one.
Rick
Jun 27, 2011 | Office Equipment & Supplies
I keep getting a cartridge error message. I have replace the ink cartridges but still have the error.
Are you using Dell Series 11 ink cartridges?
Open the printer with the power on and remove the Dell Series 11 black ink cartridge and make sure the tape is off the cartridge, then reseat the cartridge back in. Now do the same for the Dell Series 11 color cartridge. Now when you close the printer, it should print an alignment page. Any error messages?
Black = Black side(left side) Color = Color side(right side)
Photo = Black side(left side) Color = Color side(right side)
Dell Series 11 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 11 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It possible to get a Dell Series 11 Cartridge with a bad sensor. Take back to place of purchase for a replacement.
Rick
Jun 15, 2011 | Dell 948 All-In-One InkJet Printer
Lexmark 6170 Cartridge Error 50C How to resolve?
"Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 17, 2010 | Lexmark X6170 All-In-One InkJet Printer
I keep getting a cartridge 50C cartridge error on my printer. What can I do to fix it? I can't print just anything. The test printer works but I can't print anything else.
Hi there Error 50c
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
color cartridge.
Apr 07, 2010 | Dell A960 All-In-One InkJet Printer
Installed a black ink cartridge and the printer shows the message 'black cartridge missing' and also says 'cartridge error: error 50c'
Hi there Error 50c
Can only gave it a try.
color cartridge.
Nov 06, 2009 | Dell A940 All-In-One InkJet Printer
Getting error, "cartridge error" 50C. Dell All-in-one printer, model A940
Hi there Error 50c
Yes this allways happens.
color cartridge.
Oct 13, 2009 | Dell A940 All-In-One InkJet Printer
False error empty cartridge
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jun 01, 2009 | HP Photosmart C6280 Printer
Keep getting replace yellow ink cartridge error message
Where did you get the error message on printer or computer?
If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
May 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
New ink cartridge istallation: Brother MFC-240
I guess you d used generic ink carts?!
If yes, the cart holder needs replacement due to ink that has stained the led control. The ink has made a short circuit. The error can only be deleted by replacing the whole cart holder!
Jan 28, 2008 | Brother Multi-Function Center MFC-240C...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
216 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
