Question about Sony KV-35V35 TV
Tv has a red tint
Goldstar tv model gct2505m
0 characters
1 Points
Goldstar TV no Picture
What is the exact model number to your tV?
Apr 28, 2012 | Standard (CRT) Televisions
Red tint on PROTON TV picture
did u go through the menu and check for the contrast and tints?
Mar 03, 2012 | Proton NT-333 31" TV
Red tint while using component cables
Disconnect component cable while observing screen, just to make sure that is your problem. If it is and you already substituted the dvd player and it still happens,, try replacing the cable, it may be defective. If it still happens there may be some kind of a processing defect with the component input of your tv, why not just return to RCA's
Aug 07, 2009 | Toshiba 27AF45 27" TV
50 inch samsung tv has red tint n dis colored
please try to reset the color settings then hit the tint color adjustment, if nothing change, you have a problem with the RGB Section that is need to replace some small parts!
Jan 14, 2009 | Samsung DLP HL-P5663W 56" TV
Red tint to the picture
well it could be your color or tint or could be your picture tube needs replaced
Dec 12, 2008 | Mitsubishi Standard (CRT) Televisions
No red tint on TV screen
check the CRT section if there are resistor open,transistor drive of red color is leak,resold the red section of the CRT.
Sep 06, 2008 | Standard (CRT) Televisions
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
Jul 31, 2008 | JVC AV-32120 32" TV
Goldstar 27" TV
If the picture is good enough, but the transistors are usually square with a metal tab and three leg that solder to the board. Sorta like this:
Apr 03, 2008 | Standard (CRT) Televisions
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Standard (CRT) Televisions Logo
21 people viewed this question
Top Sony Standard (CRT) Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Sony Standard (CRT) Television Expert? Answer questions, earn points and help others
