Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA 56W20B TV powers off after about 5 minutes of viewing with good quality picture. Would not stay on longer.Sleep timer is not the reason for this.
    President:
  • 4,402 Answers
Read this link
http://www.hdtvoice.com/voice/showthread.php?t=33117
Posted on Jan 17, 2008
My Sharp LE820 Aquos LED TV recently auto turn itself off, when I turn it back on, a few good 10 minutes or so later it automatic turn itself off again.
Please check that the sleep timer did not somehow get set. If it's not the sleep timer, check if the panel stays ON longer after it's been off for awhile to cool down. Possibly a heat problem with the power supply or main board.
Jan 15, 2015 | Sharp AQUOS 52in. LE820 LED LCD HDTV
Works fine 30 minutes then no picture
Q502 must be top-shelf , first-quality only = no generic.
Use RCA 237470 or Sony 8-729-035-75 Both are first quality,
but RCA much less expensive..............................T.
Please rate this solution......................
Note:Blow-up caused by bad connects in horizontal driver
circuitry.Therefore,save your good,used flyback!
Nov 13, 2007 | Sony KV-35S65 35" TV
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
My radio powers off every few minutes. Needs to be turned back on by the on-off switch. How can I stop it from turning off automaticly?
When you press the Power/Sleep button the radio turns on and displays a number 90, or some other numbers. This is the play time that the radio will stay on then turns itself off. It could be that yours is configured with a sleep timer set to 01 minute, 10 or 15. You need to set the timer for a longer period. Thus we turn it on by pressing the Power/Sleep button, read the timer length then press again. Keep making short presses: The timer will cycle through all preset sleep timer durations. Select the length you want.
Jun 20, 2011 | Grundig S350 AM/FM/SW Radio
How do I use the sleep timer button?
Well you may please follow the steps below -
Step 1: Press and hold the "SLEEP" key, then release. The indicator light will stay lit.
Step 2: Enter time in minutes using the numerical keypad (from 1 minute to 99 minutes). For 1 to 9 minutes press 0 before the actual number. The indicator light will go off. Leave the remote aimed at the TV set.
The Sleep timer program can be cancelled (reset to zero) by pressing and holding the "SLEEP" button until the INDICATOR LIGHT blinks or by pressing the ON/OFF button.
Good Luck!!
Thanks for using FixYa!!
Oct 13, 2010 | RCA RCU410W Remote Control
Hi my rca truflat 20 inch tv stays on for about 30 mins then displays an analog clock and turns off
Your sleep timer is on. Hit menu, and poke through that and find the sleep timer settings. Sleep timer is something that turns the TV off after an amount of time that your do not interact with it.
Sep 17, 2010 | RCA Televison & Video
My S350 powers on when I press the power button, plays for 5-7 seconds and then powers off. What is wrong?
Mar 19, 2010 | Grundig S350 AM/FM/SW Radio
I have LG TV with XD picture quality.. but now a days it tuns off automatically then we do power off. after that it stratson powering on.. in every 5 mintes its repeat
I would believe that you don't have the sleep timer set to a 5 minute period?
If it's a few years old then the problem could possibly be in the power supply. When a component finally heat's up, then the supply goes into protect mode and turns the set off.
There are good servicer's out there that should be able to fix this. LG is really Zenith 'US' and Goldstar 'Korean'. They combined forces a couple of years ago. Zenith was well known for cracked soldering joints. This also could be the issue.
Blessings,
A/V Media Guy.
Nov 20, 2009 | Televison & Video
Powers off
check to see if our tv timers are on weekly or sleep timers may be causng the problem and shutting down and a given time
Oct 19, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
