Question about Rainbow 75th Anniversary Canister Vacuum
Power nozzle don't work
My power nozzle for carpets quit working. Used it a few days ok, everything was fine, but today, when I went to use it, the nozzle did not come on when I pressed the nozzle to make the caroet attachment work, What could be the problem? I checked everything. My model doesn't have a reset button that I can find, and I don't know where the manual is at this time.
  • 126 Answers
I don't know which model you have or how old it is, but most models have a cord on the hose that plugs into a receptacle on the main machine. Sometimes they can look like they're plugged in when in fact they're just barely hanging there. You could also check the cord at the powerhead. Because the cord flexes with the motion of vacuuming, the cords can break inside. Wiggle the cord while the machine is running and if the cord is defective, the powerhead is start and stop. On some models, there is a switch on the hose handle to turn the nozzle off and on, and these are prone to failure. Also, there should be a reset on the top right hand side of the nozzle, but if this kicked out, it indicates a motor or electrical problem and should be addressed by a service person. If your powerhead has this reset, it's possible that the reset is sticking. Push it down a couple of times and see if that helps.
Posted on Jan 16, 2008
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
Works in FLOOR position but not in CARPET.
The power nozzle has a reset button. Push that and that should fix the issue. You could of sucked up the corner of a piece of carpet causing the brush roller to become jammed. If that doesn't work, there could be a problem with the hose. The hose perhaps isn't providing the power to run the power nozzle.
Oct 12, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
My Dirt Devil CE6000 Featherlite has no power.
take it in to your vacuum store have them look at it for you.they can probably get it fixed for you.
Jul 02, 2009 | Dirt Devil CE6000 Featherlite Wet/Dry...
Powerhead on rainbow not working
If the motor is NOT running - press the red button on the nozzle (assuming you have the model with the button on the nozzle)
If it stops working as soon as you release the button - you need a new circuit breaker. If Motor in the nozzle works but brush does not spin - you have to replace the belt.
Good Luck
Nov 20, 2008 | Rainbow 75th Anniversary Canister Vacuum
Eureka Atlantis 2591A Extractor - Won't spray
Hard to say without seeing it, is there a function type knob that you would switch from carpet to hose? Did the hose attachment lid close ok? Other then take, if this is new, it has a years warranty on it, just take it to a waranty shop for repair.
Apr 20, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
No power in power nozzle
Posted by pjs5451 on Apr 06, 2008
Vacuumed with power nozzle one day working fine took attachment off to use crevice tool reattached power nozzle and no power whatsoever.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow Power Nozzle does have a reset button on the newer model on the top of the power nozzle, just push it and it should reset, or check all your pigtail connections to make sure they are connection and the cord leading to the actual Rainbow Vacuum itself. Out in left field might be that the power nozzle motor could be shorting out or not working or dead and might be in need of replacement. Check the cord for any frays or bad connections. If you have a problem please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below: Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 06, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow SE power nozzle
If the brush is spinning ok, and the belt isn't slipping, then probably the circuit breaker is bad, or the motor is causing the problem.
Oct 23, 2007 | Rainbow 75th Anniversary Canister Vacuum
Rainbow 75th Anniversary Canister Vacuum Logo
168 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
