Question about Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television
No picture for the TV
My TV just turned off and it is making a sreeching noise when turned on (No picture)...
Do i need to buy the bulb...i have not changed it for 4 years...
Help...
Thank you
  • Sony Master
  • 8,617 Answers
The bulb wouldnt make it screech, that sounds like a bearing in the color wheel. You may want to consider getting a service manual for your set. If so you can get one for your model for 10.99 at the following link, and they will email it to you if you go back to the site and request that they email it instead of regular mail. Hope this helps. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Jan 20, 2008
I got a 52" zenith
No,the tv message said replace lamp wright?Yes,mean the tv projection lamp is the causes and the problems.The tv projection lamp life span have ended that why the tv it is not holding a stable tv projection lamp picture.All throught these causes,does the tv make alot of clicking noises too,when the tv projection lamp is it on for 30 sec.and shut it self off?Yes,than the board that call the Ballast board it is also dead too.This Ballast board only job are to ignite the tv projection lamp only.Tries websites like Partstore.com,Ebay.com to buy a new tv projection lamp and a new Ballast board too for the replament too,if this tv causes have alot of clicking noises,when the tv is trying to ignite the tv projection lamp.
Aug 09, 2011 | Zenith D52WLCD 52" Rear Projection...
My mitsubishi wd 73733 just made a popping sound and went off.when i tried to turn it back on its making noises with no picture goes from a green light to blinking red on lamp inicator do i need a bulb or...
You can actually go with just buying a bulb. I have seen many cases where televisions stopped displaying a picture due to a worn out bulb. The noise is also from the weak bulb.
Mar 13, 2011 | Mitsubishi WD-73733 73" HDTV
SAMSUNG DLP SLIM 50" AFTER I TURN IT OFF IT WONT TURN BACK ON TILL 30 TO 50 MINS LATER THE THREE LIGHTS IN THE FRONT BLINK. iT ACTS LIKE ITS GONA TURN ON BUT IT DOESNT IT JUST MAKES THE NOISE AND FLASHING...
Chris,
I had the same problem. I bought my tv at Best Buy and my warranty included a new bulb for the lamp. They only last about 2 yrs or so depending on how much you watch the tv. You can also buy replacement bulbs online that don't cost too much. BUT, you will need to replace every couple of years. The things you listed are exactly what happens when the bulb goes out. Hope this helps!
Sep 14, 2010 | Samsung 50" Slim-Depth DLP HDTV
When trying to turn on my tv, the green light blinks a few times then the red light blinks a couple of times then automaticaly the tv shuts off. There is no picture at all. It makes a couple of sounds like...
sounds like the projection bulb went bad. change the bulb and it should work. sometimes they make a high pitch noise when they are trying to turn on. the bulbs seem to last about 2 years for me.
Jun 04, 2010 | Zenith E44W46LCD 44" Rear Projection...
Brush problem
does the motor turn? maybe it is jammed
Jan 07, 2010 | Dyson DC14 All floors Bagless Upright...
Turns on and off then back on then off
Discovered bulb had blown out.
At power on button, red light and green light flashed and no picture was present. I opened side panel after unplugging tv and let the bulb housing cool, then removed the bulb and discovered it had blown. Luckily I had a replacement bulb from the purchase, replaced it and it worked again.
Oct 01, 2009 | Toshiba 52HMX84 52" Rear Projection...
LG DLP Suspected Faulty Bulb... how to be sure?
First pull back off turn TV on watch Fan behind lamp more then likely it is going bad Fixed LG 9months ago and it was the Fan.If Fan Stops turning Lamp will not light.
Aug 06, 2009 | LG Televison & Video
I have a Toshiba 52HMX94 rear projection T.V., i've had it for 4 years, replacing bulb every year. I now have another new bulb, but when I turn on the T.V. i hear a buzzing noise from the rear, and then...
Your TV requires ballast power supply board that gives you buzzing noise when TV turns ON.
Ballast supply board is available in Part Store and replacement of that board requires expertise.
Jul 23, 2009 | Toshiba Televison & Video
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
Magnavox 50" DLP Tv power light comes on but then i hear a buzzing noise and then two red lights come on the tv. at no point does the picture turn on during this time. Can you please give me a possible...
Your bulb is burned out. I have had the same problem. It seems this television has an overheating problem--and short bulb life. I have had our 50 Magnavox dlp for two years and just put in the second bulb before Christmas. You can buy the bulb from a dealer on ebay for $99 and install it yourself. I is not in the housing so you have to carefully take out 4 screws and replace the bulb without touching the face of the bulb. To buy the one from Magnavox with the housing is much more expensive. I think the first time my husband replaced the bulb it took about 45 minutes--this time it took about 20.
Dec 16, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Logo
69 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
