Question about Pioneer PRO-200 60" Rear Projection Television
Replacing power board on pioneer pro 200 elite
A guy said i can have the tv if i can move it. roughly what will it take to fix?he had a technician come out and the tech said that the power board needed to be replaced. wondering what it would cost me to do it.
  • red24 Jan 16, 2008
Check the thread about resoldering the power may have to be done by someone who is qualified but I'm sure it will be a lot chaper...that's the route I'm gonna go!
Posted on Feb 03, 2008
  • Pioneer Master
  • 8,617 Answers
364.00 for a new Power/deflection board through pioneer. i am including a link to their site. You may find it cheaper someplace else on line, but pioneer will have better quality parts. hope this helps. heres the link.
Posted on Jan 16, 2008
It is not an easy to do work, as you assume. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 16, 2014 | Pioneer Elite PRO-1540HD 60 in. Plasma...
Pioneer Pro Elite Rear Projection TV with Sudden loud pop then shuts down
You may need the power supply board resoldered as I had the same problem. The guy listed below can do it for you as I shipped mine from Illinois to him in California... Piece of cake getting the board out of the back and it's not too fraigile... Just pack in bubble wrap and it will be fine. My TV is now working great.
Good luck.
on Jan 16, 2008 | Pioneer PRO-200 60" Rear Projection...
Pioneer elite turns on then shuts off right away
Shutdown can be caused by many different things in the set. Do you get an blink codes from the power LED on the front of the TV? You can order boards and get help from the technicians from part suppliers I often use.
Nov 04, 2013 | Pioneer Elite PRO-1140HD 50 in. Plasma...
My Pioneer Elite PRO-111FD just shut off on it's own, and now won't turn back on. No green or red indicator light... nothing. Any suggestions?
Check your power source (electrical outlet) and the power cable. If electrical outlet is ok, try using a different power cable (the cable that you plug on to the electrical outlet going to your TV set). If everything is ok but still no indicator light, call your technician there might be a problem with the TV power supply.
Sep 08, 2010 | Pioneer Elite PRO-111FD 50 in. Plasma TV
Problem with pioneer elite pro-99
your tv's hardware might got the problem. this should fix with an expert technician that they have a tools for fixing this problem. if repairing will cost you alot then i suggest that you have to buy a new tv insted of repairing your old tv. hope that helps!
Aug 21, 2008 | Pioneer PRO-99 TV
Pioneer elite pro 118
if the tv is more than 10 years old no its not worth replacing the power supply.if its 5 years or newer yes it owuld be worth the money
Jul 17, 2008 | Pioneer PRO-200 60" Rear Projection...
Pioneer Elite Pro-200
When it shuts itself down it is for the protection of the unit from further damage. It appears there may be something wrong with the power supply of unit. If you can get an inexpensive replacement board you just might want to go that route. On the other hand you have already gotten ten years out of it and you might want to move on.
Sep 01, 2017 | Televison & Video
Pioneer Pro-118 won't turn on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine. Check all three fuses while you're in there.
Feb 12, 2008 | Pioneer PRO-200 60" Rear Projection...
"TV Not Turning On"
Hey im not one of the techy guys with tv's im a computer guy.
but i have that same pioneer set you have the 510-HD and i had a similar if not the same problem.
my ex-father in law is a tv repair guy he told me to resolder the power board connections that looked corroded. i did just that and problem solved. hope this helps you out
FYI make sure you use rosin core solder not acid core good luck
Nov 27, 2007 | Pioneer PRO-510HD 53" Rear Projection...
Convergence Problem Pioneer Elite 60"
It sounds like the convergence IC's are bad unless someone has got inside the set and tampered with some adjustments or the set has had a recent rough move. Other possibilities would include defective capacitors/resistors or connections in the convergence circuits or power supply area.
Feb 09, 2007 | Pioneer PRO-200 60" Rear Projection...
Pioneer PRO-200 60" Rear Projection Television Logo
113 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
