I have a SIEMENS GIGASET 4215 with two handsets. They have been working fine both before and since I moved in April 2007.
A few days following a two-hour power outage, the thee phones began to flash "base 1" and it was not possible to make or receive phone calls.
I removed each phone from the stand/charger and took the batteries out of the phones.
I recharged the batteries and replaced each phone in its stand. It flashed "Base 1". It just kept flashing this way. So I pressed the [END] button to re-register each phone - starting with the base unit - and replaced in the stand and it flashed "Searching...". I left it like this and it just keeps flashing "Searching...".
Is there a solution to this problem, or should I just scrap these phones and start over with new ones?
Many thanks for your help.
JSD
Comments:
Jan 29, 2008
- Thanks Geno69.
I tried your suggestions - 3 times with each handset without any success. Currently two handsets are flashing 'Searching' and one is flashing 'Base 1'.
I didn't previously indicate that the 'signal strength' icon is also flashing at the same time, and is 'blank' (no black fill on icon).
I don't know whether or not this has any bearing on the problem but the phone batteries are fully charged and the 3 phones are standing side-by-side, plugged in and with the handset(s) firmly in the stand(s).
I appreciate and thank you for your trouble.
Mar 05, 2008
- Thank you Genoa69. I appreciate your expert input. Now I know not to waste any more time on this and will proceed with a replacement phone set.
Try this:
Pick a handheld, press Menu - H/set settings - Reg Handset - Select Base 1, enter 0000 as password. Now on the bottom of the base station press and hold the Register button in for about 10 seconds or until the h/set beeps.
Geno
Comments:
Jan 23, 2008
- Also for the Siemens 4215 base, there is a hidden rest procedure to manually reset the entire base:
1. Unplug AC adaptor
2. Press and hold reg button on bottom of base.
3. Plug in AC adaptor while holding in reg button.
4. Keep reg button held in for 25 seconds then release.
This should reset the base to factory defaults with a password of 0000.
Then register handsets as stated in my previous post.
Geno
Mar 05, 2008
- Then the base is bad. I have 2 of them like that. Both seemed to happen when I let the ans mach hit it's limit. When I got done deleting messages, the unit was dead and no handsets would register. I think you now have a brick.
Geno
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Oct 04, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Geno69's solution (step 1 and 2) worked for me with a siemens gigaset a160.
Popular Solutions for Siemens Gigaset 4215 Cordless
I am at a loss for the pin number for the handset for the Siemens gigaset 4215. I just purchased the...
(More)
I am at a loss for the pin number for the handset for the Siemens gigaset 4215. I just purchased the phone for the in laws and have been trying to program for 3 days now without anyluck. HELPPPPP Thank You
Hi - our answer phone worked fine with BT, and now we have moved to Virgin, it answers but doesn't...
(More)
Hi - our answer phone worked fine with BT, and now we have moved to Virgin, it answers but doesn't indicate that theres a message and you cant seem to retrieve it - any ideas
Not a problem, but a general ?. I have a siemens 4215 gigaset phone & would like to confirm...
(More)
Not a problem, but a general ?. I have a siemens 4215 gigaset phone & would like to confirm if the answering is actually built in the handset or the base? I know the controls are on the handset, but is the answering machine actually built into the handset or the base. Thanks
Baase not transmitting a signal. There is nothing being shown for signal strenght in the upper left...
(More)
Baase not transmitting a signal. There is nothing being shown for signal strenght in the upper left corner.
answering machine -- i don't want to delete all saved messages. the navi button no longer forwards...
(More)
answering machine -- i don't want to delete all saved messages. the navi button no longer forwards to the next saved message; pressing 3 does. however, the delete / OK choices no longer appear on the screen. any help would be appreciated. thank you, John
