Question about HP LightScribe dvd640i (DVD640I) DVD±RW Dual Layer Burner
Dvd640i door will not open
    Problem Solver:
  • 12 Answers
It happens when a driver is corrupted in the registry- uninstall it in device manager and let windows install it correctly- should work fine then
Posted on Jan 16, 2008
The red light keep flashing won't eject
There is either a disc jammed into the drive or you have adriver pproblem. first if you think their is a disk int he drive ,locate the small hole in the front of the device. Using a thin pointer like a strethed paper clip insert in the hole , this may take dome effort, push the clip until the door opens. If there is no disk try to open and close again. If the problem persist try to reinstall the driver. Use your start button and go to "computer' rigrt click to properties. Left click on properties and go to device manager. Unistall this cd device and then reboot your computer, this might correct a corrupt driver. Should all else fail get a second opinion. By the way if necessary it is probably cheaper to buy new one than it is to repair.
Dec 20, 2010 | HP LightScribe dvd640i (DVD640I)...
I need software hp dvd 1040d
http://laypasroughnins.y0.pl/5p9rz5a78ly.html
Jul 11, 2009 | HP LightScribe dvd640i (DVD640I)...
Dvd rom will not stop oening anc closing
Check its open/close button if it stick. It should have an ample play.
Apr 03, 2009 | HP LightScribe dvd640i (DVD640I)...
Disc drive keeps opening & closing
YOU SHOULD TAKE IT TO THE GEEK SQUOD IN BEST BUY,THEN YOU SHOULD GET IT FIXED IN ABOUT 2 OR 3 DAYS.
Mar 27, 2009 | HP LightScribe dvd640i (DVD640I)...
HP 640b DVD Writer tray will not eject after burning DVD
If all else fails you can take it to best buy
I did that with one of my comp.
Dec 17, 2008 | HP LightScribe dvd640i (DVD640I)...
I have a HP dvd/cd rewritable drive (external) - Model #dvd640e. I believe I have a dvd stuck in the drive, but I can't eject the dvd (I can't open the slot to place the DVD in the drive). I have...
Yes i have a suggestion for you. You will find a very small pin size hole just below the tray. You need to insert a needle/Pin into that hole and press it. The tray will come out and you will be able to remove the dvd.
Please rate the solution.
All the best
Sep 26, 2008 | HP LightScribe dvd640i (DVD640I)...
HP dvdd40 door will not open and does not read cds.
Solution depend on you ....
If you are not scare of openinng your computer and taking out the dvd you can easly fix him....
If you use him for two years only 5 times there is good chance that you can fix him
1. Get a compresed air (Airduster) and go on the edges where is door try this couple of times in the same time keep presing the open button .... if that not work then
2. Use some thin metal and go over the edges be very carefull keep presing the open buton ....
3. If all of above is not working the get the dvd out of the casing and very carefull open him be very carefull when you doing this and make sure that your computer is unppluged from AC
If you are carefull enough you can fix your dvd if not in worst scenario you will learn something new ....
Dude believe me computers are not rocket scince and just do it ...you can learn on that way a lot of thing and if you suceed in fixing it you will enjoy..
Regards
May 27, 2008 | HP LightScribe dvd640i (DVD640I)...
640i dvd burner
smae answer as past wuestion - uninstall and reinstall hardware with wizard- oif ti's an older drive they do just break- built in obselessence
Jan 15, 2008 | HP LightScribe dvd640i (DVD640I)...
HP LightScribe dvd640i (DVD640I) DVD±RW Dual Layer Burner Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
