Question about HP OfficeJet D135 All-In-One InkJet Printer
While receiving a fax
The Machine jammed and after I cleared the jam it says that the printer cartridge carriage has stalled. I cant turn it off What can I do?
  • stuart alan Jan 16, 2008
    the machine is on, it says "printing fax page 1". The problem is that it will not print. When you shut it off and turn it back on, you hear a loud plastic scraping sound. There are new ink cartridges in the machine.
  • 24 Answers
Resolution for Lynne:
1. Unplug the power cable from the pwer strip and open the front door of the printer and move the carriage(in which the ink carts are connected) from the left to right and then back again for 2-3 times.
2. Plug in the pwer cabe and turn on the printer and print the h/w tets page.. if it prints fine, then try to, send and recieve a fax, If the carriage agains jams then replace the printer or serviec the printer.
Resolution For Stuart:
1. Th scrapping noise indicates that the ink carts are not inserted in the printer slot properly.
2. Pull the ink carts out and then push them back in and mak sure the printer should be on .
3. Clear the queue and then print the h/w test page, if prints fine then go ahead with fax.
Posted on Jan 22, 2008
Carriage jam
The carriage door is the cartridges access door.Access the cartridges and make sure they're properly installed.To open:
  • Turn the machine on.
  • Open the cartridges door by lifting from the front center of the device until the door locks into place on its own.
Feb 27, 2012 | HP C6250 InkJet Printer
I have a HP Photosmart C4280 al--in-one printer. This morning it refused to copy a document. It also refuses to print. Always there is a message "carriage jam. Press OK". This does not cure the...
The Carriage Jam error message displays on the control panel display. The print carriage, which holds the ink cartridges, stalls against the left side of the printer. A paper jam might have occurred previously.
Sep 02, 2008 | HP Office Equipment & Supplies
HP PSC 2355 try to print a document and receive an error "Print cartridge carriage is stalled " "Open door, clear carriage jam, and then press OK to continue." I tried this and there is...
This can be said as a bit complicated problem. This problem is exhibited by the printer when the cartridge carriage mechanism is getting stuck at some end. I should advice that you make sure that the SS ( Service Station ) of the printer is not jammed / clogged. If yes, try cleaning it. It is also caused when the motor is malfunctions and tries to move the carriage beyond the path that it should go.
It is best recommended that you consult an authorized HP Service person for the solution of this issue.
Thank you.
Mar 06, 2011 | HP PSC 2355 All-In-One InkJet Printer
Whenever i try to print it does 1/2 page then the cartridge keeps getting stalled on one side. Error message on screen says print cartridge stalled, error message on printer says clear carraige jam. Cannot...
If there's a carriage jam. While the printer is turned on, Open the access door of you printer.
If the carriage is stuck at the left side, try moving it manually by hand to the right most part of the window. If it's stuck on the right, try moving it by hand to the left.
If you've already done that. While the printer is turned on, unplug the power cord from the back. Close the access door. And then plug it back in.
Make sure you restart the computer first just to avoid documents getting stuck in the print queue. Try printing again. Usually it does the trick.
Feb 03, 2011 | Office Equipment & Supplies
HP OJ 5110 the print cartridge carriage is stalled problem open door, clear carriage jam, then press enter. plz problem describe in hindi
door close ka sensor thik se kam nahi kar rha hai. ho sakta hai ki paper jam hoa hai. saaf karo, cartridge fir se nekal kar install karo. print cartridge carriage ke rod par thora sa tel lagao
Dec 13, 2010 | HP OfficeJet 5110 All-In-One InkJet...
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How to Clear carriage jam on HP PSC 1610 Printer? No obvious paper jam visible.
Dear it's the carriage jam error. so it mean that your carriage is jam not paper. so open the printer where you insert the cartridge. check whether it is jam or what . cartridge carrier is jam kindly turn off the printer and try to move the cartridge head by hand very gently and if seems to be stuck than check for anything which abort him to move freely so than might be anything like dust or else. when you get success in moving the head put some machine lubricant on the rod on which head moves and check it ok.
Dec 04, 2008 | HP Office Equipment & Supplies
HP OfficeJet D135 All-In-One InkJet Printer Logo
Ben Johnson
