Question about All-Pro SPC-85 Utility Heater
After lending my heater to a "friend", I now have to hold the igniter button on to keep the flame lit. Is this repairable or do I need replacement parts.
If so, do you sell them, or can you tell me where I can obtain them?
Thanks much
Mike Gegory
c- 602 818 4472
  • 4 more comments
  • Trott57 Jan 28, 2008
    I have the same problem as Grogs with my heater. Can the thermocouple be replaced with an after market product?
  • Anonymous Mar 27, 2008
    The problem with going to a hardware store is finding a thermocouple that has the two spade connectors used to inform the logic board that heat is present. All I'm finding are standard water heater thermocouples w/o the spades.
  • Anonymous Apr 09, 2008
    My heater has the same problem. I need to hold the button in to keep it lit.
  • tmassett Apr 11, 2009
    yes, I have the same prolem. Is it the thermocoupler that is not keeping the gas valve open and is that a replaceable part.
  • xray xavior
    xray xavior Nov 25, 2017
    I can tell you how to fix all your issues with that heater, for free.
    kelp23@excite.com
  • xray xavior
    kelp23@excite.com
  • 232 Answers
Another source for heater parts is www.reddyparts.com .
Posted on Sep 26, 2008
  • xray xavior
    I can tell you how to fix that heater, for free.
    kelp23@excite.com
  • 1,420 Answers
Check the thermocouple, it is a very small diameter copper wire that goes from the gas valve to the burner. Make sure it is being hit by the flame. If it is, remove it and go to a good hardware store with it and get a new one.
Posted on Jan 16, 2008
  • xray xavior
    You don't need to go get a thermocoupler. I can tell you how to fix it, for free.
    kelp23@excite.com
Reddy Parts has the thermocouple for the allpro heater part number 104146-01. $25 plus $10 shipping. Cheaper than Desa Parts.
Bob...
Posted on Dec 21, 2009
  • xray xavior
    Forget payin for parts. IO can tell you how to fix it, for free.
    kelp23@excite.com
    New Friend:
  • 3 Answers
I can tell you how to keep your heater runnin, usually for free. Mine is 17 Yrs. old and still works great. I only bought one part for it, a coil board, but in the future i will make my own igniter, for free. I opened up the jets and it cranks out the heat.
kelp23@excite.com
Posted on Nov 25, 2017
  • xray xavior
    xray xavior Nov 28, 2017
    Fix your all pro heater for free. I can tell you how. No need to go buy expensive parts. kelp23@excite.com
  • xray xavior
    xray xavior Dec 22, 2017
    Forget all that. I can tell you how to fix your heater, for free. No app needed.
    kelp23@excite.com
  • 26 Answers
You can also get the parts at www.bealsmotor.com
Posted on Jan 20, 2012
  • Anonymous Nov 25, 2017
    The only parts ever needed to keep it runnin is the coil board and fan. The coil board can be home made also, savin money. Everything else can be fixed, for free.
    kelp23@excite.com
For your All Por Propane Heaters. You can obtain parts from: DESA Heating Products. www.desatech.com. Hope this helps Ed
Posted on Apr 09, 2008
    I can tell you how to fix it, for free. Mine is 17 Yrs. old and still works great.
When you release start button it quits
this unit like most has a heat switch and a thermal coupler they work to gather jump the switch if it runs then its the switch if it doesn't then its the thermal coupler flame should hit the coupler and turn red loose wire on switch has happened before to
Dec 04, 2013 | All-Pro SPC-85 Utility Heater
Heater won't stay lit without holding the button in
kohlgraf,
I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which should explain your problem and how to fix it as well as where to go to get the parts. All these types heaters (Reddy, All Pro and Master Heater) were made by DESA international.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 25, 2011 | All-Pro SPC-85 Utility Heater
Heater wont stay lit when i let go of primer button after a few seconds
try holding down the button for 15 to 20 seconds and then let go ( this will let the system heat up to the proper temp ),, if it still will not stay lit then the thermal coupling is bad and needs to be replaced.
c...
Jan 24, 2011 | All-Pro SPC-85 Utility Heater
Unit will not stay lit unless the bottom is held down manually.
This indicates you have a bad thermocouple. It's the copper probe that goes down to the flame. You may be able to pick up one at a good hardware store such as Ace.
Jan 08, 2011 | All-Pro SPC-85 Utility Heater
Heater won't stay lit after releasing yellow button
you need to replace the thermocouple at the burner tip it will be a copper line with a bulb in the flame tip with a copper tube leading back to the gas valve and it senses the flame and keeps the gas valve open
Dec 24, 2009 | All-Pro Propane Garage Shop Heaters - All...
SPC-12 SPACE HEATER WON'T STAY LIT?
When holding button in,you are overiding themocouple funtion. You probably need to replace the thermocouple
Feb 27, 2009 | All-Pro Propane Garage Shop Heaters - All...
All Pro SPC85
what you mean "plunger?" the reset button?
Jan 05, 2008 | All-Pro SPC-85 Utility Heater
All pro spc-85
going through the backplate to the nozzle location is the thermocouple. it is a copper like tube that sits back from the actual flame. if you are looking for a replacement go to www dot desatech dot com.
Dec 11, 2007 | All-Pro Propane Garage Shop Heaters - All...
All-Pro SPC-85 Utility Heater Logo
2,271 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
T bone 1963
Mack Baxter
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
