Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Blue Screen When tv turned on the left side of the display is blue. The rest of the screen is fine.
  • grantly Sep 29, 2008
    When TV is turned on left side of screen is blue with the other part fine.
How do i get ride of the blue box in the screen area.....?The rest of pic is fine....
Posted on Sep 28, 2008
Westinghouse SK-26H520S LCD TV has blue screen on the side
Vertical color scan has an open or short..............it could also be a ground problem with in the V-color scan circuits...
If you tap the tv and the color bar is gone then its a ground problem with in those circuits above. Needs a solder re-flow and check the condition of ribbon cables.
CWR
Oct 29, 2009 | Westinghouse Televison & Video
LCD blue on bottom screen
replace the cold cathode(s) that lights your display it is like a small florescent lamp
Aug 30, 2009 | Sony KDF-E42A10 42 in. LCD Television
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
Jensen t.v model ts2750j blue screen red lock upper left
My Advent TV did the same thing. Blue Screen with a red lock in the upper left corner. Just press and hold the display button for about 10 seconds. It will clearn
Feb 02, 2009 | Jensen TS2750J TV
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Blue color spread over the pictures
This sounds classic to a thermo problem where a part(s) are becoming thermo sensitive with aga and use. When the set is cold and then warmed up, the defective part(s) is changing characteristics.
Some components became thermo sensitive that are driving the display. Or an embeded component in the display itself became thermo sensitive. It is very possible that the fault is on the board that does the X - Y addressing or on the backplane electronics of the display screen itself.
Using the set with defective components is a bad idea. If the part(s) fail completely and go shorted or opened, other more costly damage can be done.
The service rep for the manufacture of your set is equiped and trained to be able to troubleshoot and service your set.
You will have to take the set in to have it serviced.
Jerry G.
Apr 17, 2008 | Vizio GV46L 46 in. LCD Television
Convergence
Did you remove 1 leg of each resistor out of circuit when you checked the resistors? sounds like thier is still one resistor open or maybe one of the new IC pins need abit more solder.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Blue is distorted
Find and examine the conv ICs, on their big heatsink. They may be unsoldered down at their legs, or need replacement.
Mr Bob
www.imageperfection.com
Nov 11, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
144 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
