hi i have a whirlpool washing machine model no awo3761/5 it's drum is not moving but if we put it on drain it's working ok bt when ever we put it on waqshing it's door light start flashing afte 30 sec and drum does not moving is it poosible u tel me smthing thnxx
-   i HAVE GOT THE HOTPOINT AQUARIUS EXTRA WMA40 AND THE DRUM DOES NOT SPIN AT ALL. I HAVE TRIED OPENING THE BACK TO CHECK IF THERE IS ANY PROBLEMS WITH THE WATER HOSE BUT THAT DID NOT PRODUCE ANY RESULT.-   Guest
Best Solution
posted on Feb 04, 2008
Guest
Rank: Apprentice
Expert
Rating: 0%, 0 votes
Hi, I have the same problem with the same machine! I've tracked it down to a broken belt.
the flashing door lock is indicating the brushes are worn down on the motor and thats the reason why it wont turn at all
the brushes wont take u no more than 10 minutes to replace
if u know what your doing
as its basicly 2 screws each brush and a wire that has to be reconected
then all will work as new
You could try the brushes on the motor its possible they have worn down you could also check out the pressure switch contacts and diaphram to ensure it is sufficiently sealed and air tight.
where is the filter i have got a horrible smell coming from the washer and dont know where it is...
(More)
where is the filter i have got a horrible smell coming from the washer and dont know where it is coming from
when i switch my dads hotpoint washer on it does a short fill for pre wash does a part of the cycle...
(More)
WHEN I SWITCH MY DADS HOTPOINT WASHER ON IT DOES A SHORT FILL FOR PRE WASH DOES A PART OF THE CYCLE THEN STOPS, THE PREWASH LIHT CONSTANTLY FLASHES, I DONT GET A FULL WASH CYCLE, ANY IDEAS PLEASE, HES DISABLED SO NEED IT FIXED, THANKS
I did a maintenance wash on cycle b therefore with no laundry and it got to the final spin stopped...
(More)
I did a maintenance wash on cycle b therefore with no laundry and it got to the final spin stopped but the door locked and final spin light have stayed on but not flashing, static and i therefore cannot open the door, what do you suggest?
Unfortunately the unit was started before the protective screws were removed - does this completely...
(More)
Unfortunately the unit was started before the protective screws were removed - does this completely ruin the unit? To all intents and purposes it works, you can select your cycle, but when you press the start / pause button the unit beeps and the door light keeps flashing.Any help with this would be appreciated.Tom
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
