Question about AudioBahn A8002T Car Audio Amplifier
AUDIOBAUN A8002T Car Audio
Car not running, everything fine!
Car running , amp turns on for approx. 10 second then goes into protection.
Even when amp RCA's removed,Speaker wires removed & gain as low as it will go , it doesn't change.Car running voltage does not exceed 14.4volts while running , Ran fine on our board for days after repairing 4 IFRZ44N 's and 4 100ohm resistors in front of them.Feed from factory deck with line level reducer with isolation transformers on grounds.
Note:If I push the lock/unlock door button in drivers door the amp will come out of protection for a couple seconds then go back into protection.Weird!!!
Any help would be Greatly appreciated.
Thank
Les Saunders at All Electronic Solutions , London ,Ontario,Canada
  • 107 Answers
Add doide from the battery to the unit, 2 doide should help that.
1 connected to the positive, an 1 connected to the negative. 5-10 amperes is ok. check for the polarity. and try to take off the ground of the unit then try it.
Posted on Jan 18, 2008
6ya staff
SOURCE:
My protection light will not cut moff
if the protection light is on an everything is hooked up correct then its got to be on the inside of the amp
Jul 18, 2011 | AudioBahn A8002T Car Audio Amplifier
I hooked up 2 capacitors into my amp and every time I put power to it the amp shuts off and 10 seconds later a red light comes on for 5 seconds and the amp don't turn on, basically it goes into protect...
Well, I have no idea why you would have two capacitors on a 500 watt amp but, did you charge the capacitors? Have you tried the amp without the capacitors? What size power wire are you using?
Sep 20, 2010 | Kenwood KAC-9102D Car Audio Amplifier
I have a JBL1004 amp in my ski boat. I killed the battery listening to the stereo and caused the battery to lose a cell and drop to 10 volts. The stereo cut out as one would expect. I have replaced the...
if the protect light comes on then you might not have enough voltage running to the amp so you would need to add a second battery just for that amp.
Jul 26, 2010 | JBL GTO1004 Car Amp
Bumps good but every 10-15 min of bumping it
to much power hooked up to it take something away
Jul 21, 2010 | AudioBahn A8002T Car Audio Amplifier
Audiobahn a8002t schematic
audiobahn.com under tech support you can download your manual for almost any thing even shows you wiring diagrams helped me out...
Mar 01, 2010 | AudioBahn A8002T Car Audio Amplifier
Audiobahn a8002t amplifier in protection mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. D .A thumbs up would be greatly appreciated if this answer is helpful to you. audiobahn-a8002t-amplifier-in-protection-lv2kkrmxrai4iihdvw4m3np2-2-0.jpg
Dec 21, 2009 | AudioBahn A8002T Car Audio Amplifier
I need a installation manual for audiobahn a8002t amp.
very simple run a ground from gnd on amp to a good ground spot on car run 12 volt power cable from back of fuse relay by battery to 12v+ on amp then splice blue wire on back of stereo splice in another wire about seven feet run that to remote on amp then hook up speakers its pretty simple to hook up an amp hope this helps
Apr 18, 2009 | AudioBahn A8002T Car Audio Amplifier
ABR100T Audiobahn Bass remote not working correctly?
i had the same thing happen to me on my 2300hct audiobahn. it turned out to be the remote. but soon after my amp went dead. i than switched to JL no problems since.
but i still use audiobahn immortal 12's.
Apr 11, 2009 | AudioBahn ABR100T Remote Bass Control For...
Audiobahn A8002T
The most common cause for an amp to go into protection is shorted output transistors. To eliminate other possible causes, read through the following page.
Troubleshooting - Amp in Protection
Let me know if you have any other questions.
Jul 23, 2008 | AudioBahn A8002T Car Audio Amplifier
Protection light grief
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Vibe is mediocre. Time to invest in an old school Lanzar Opti Drive amp. .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-light-grief-shonxoarcym4awy4zl1imx4o-2-0.jpg
Jun 11, 2008 | Lanzar VIBE266 Car Audio Amplifier
AudioBahn A8002T Car Audio Amplifier Logo
165 people viewed this question
Top AudioBahn Car Audio & Video Experts
Dalynn Turner
Professor_V
Professor_V
matthew walsh
Level 1 Expert
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
