Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Hoover widepath steamvac
My Hoover widepath steamvac will not suck up the dirty water. Actually it never has...what is the problem.
  • 1,673 Answers
Re: Hoover widepath steamvac
One cause is the filter in the dirty water tank lid is pushed up too high, it needs to have a gap of 1/4 in or so. So check it, if it is up all the way, pull it down some.
Posted on Jan 15, 2008
0 characters
3 Points
Hoover SteamVac F6030-900. Does not **** up
check the black plastic motor cover. these frequently melt and loose seal due to the extreme heat of the motor. if the plastic is warped, then that is the problem. also check for hair and cloggs throughout the suction ports
Feb 26, 2010 | Hoover F6030-900 SteamVac WidePath Wet/Dry...
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Vac not sucking up water
its supposed to, it means you need to dump out the tank. Its a safety feature that keeps the water out of the motor. if its lifting up due to foaming, than try using the original brand shampoo
Jul 13, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover V2 SteamVac
Under the detergent side, there is a metering plate,(located on the machine) which can be removed. ensure that this is installed. have you verified whether the machine will dispense detergent only without any water in the water tank?
Jan 03, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Dirty water is leaking back out
After shut off all steamvacs will leak dirty water that was sucked up back out. There is always some left in the nozzle. If it is a large amount there is clogged filter that isnt allowing the proper suction. Refer to your manual or go to to download one for cleaning directions.
Jan 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steamvac Widepath 6500 leaks
You didn't give your model number, but if this is a V2, you may have a crack in the tank, alot of times it is underneath the seal on the bottom. Or the plunger at the bottom of the tank is stuck open or missing.
Dec 02, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes are not moving
You should be able to get a manual from Hoover.
Oct 21, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover SteamVac 5863-900
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter, or the lid for the dirty water tank is not locked down on th e tank.
Aug 28, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
513 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
