Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
Freeze on bottom but not on top
I have a kenmore up right freezer it is about 5 years old. We moved a year ago I never plugged it up until the other day. It will freeze something if you set it on the bottom but anything on the middle or top shelf will not freeze or stay frozen.
Thanks
  • 2,042 Answers
When you plug it in do you ear a fan running if not plug the freezer on.and at the bottom of the freezer gently hit were you have a grill sometime the fan motor gonna start running and circulate the cool air if it work keep and eye on it for a few days take care cheers
Posted on Jan 15, 2008
6ya staff
SOURCE:
Www managemyhome com
I would suggest you have it serviced, sounds like the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. To repair an engineer will first cut the coolant pipe and drain the existing gas and then recharge, re-pressurise and seal.
Jan 04, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Used Kenmore freezer won't get cold enough
If it is running but not cooling enough the problem is in the sealed system.
If you started it up just after hauling it home it may have be moved around enough to get oil in the systems smaller tubing causing problems. Unplug the unit for 24 hours and let it sit. Try it again for 24 hours and see if it cools.
If not this means either there is a refrigerant (freon) leak in the system or a restriction causing the refrigerant to not flow properly.
Either one are an expensive repair. and will require a professional to look at.
May 09, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Only one half of my chest type freezer freezes? It is old. Bought at least 18 years ago. Help!
My recommendation is to get rid of this 18 year old freezer as it is costing u a fortune to keep it plugged in. Then ask yourself if you really need an additional freezer at all?? If you do, consider purchasing a new small one that is really energy efficient. You will be way money ahead I assure u.
Apr 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire freezer 5 cu. / ft.
how old is it ? and if is just humming is etheir a locked compressor wich if it is then depending on age if is less than 5 years from todays date then just call frigedaire and they will fix it for free but is it was manufacture more than five years ago then is trash , now is just the overload then just buy the part and replace it and you will see if it turns on the overload is the part siiting right on the left side on compressor , fyi the maunufactures date is on the name plate on the wall i belived is on the left hand side
Nov 02, 2008 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezer Not Working
The most likely answer is a slow freon leak assuming it was getting to the right temperature before you went on vacation.
Jul 16, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
380 people viewed this question
Top Kenmore Freezers Experts
John Tripp
John Tripp
Felizardo Erilla
Felizardo Erilla
PNiss
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
