Question about Apple iPod nano
Ipod will not resprond to itunes
When I plug my ipod usb ioto my computor i come to the itunes web site and my ipod shows up on the left sideunder devices, but then i click on it i get on (set up your ipod) page, 1. Automatically sync songs to my ipod
2. Automatically sync photo to my ipod. and i can't do anything past this point.
  • jarrett11 Jan 21, 2008
    i need help
    President:
  • 4,402 Answers
Get sharepod. works better less problems.
Posted on Jan 31, 2008
Remove password ipod
Depending on the model of your ipod it will differ
iPod Classic password
This works on an iPod 5 th gen
Click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
Click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
Right click select rename to open or delete the folder your Ipod should now be open
ipod touch password
Launch the iTunes program on your computer and click "Help" on the main menu.
Scroll down and click "Check for updates."
Close iTunes.
Connect your iPod to the computer using the supplied USB cable.
Launch iTunes, which will display your iPod on the left panel.
Right-click your iPod in the iTunes program and click "Eject."
Close iTunes and detach your player from the computer to unlock it.
http://www.youtube.com/watch?v=5uT8Utk5Tqg
ipod iphone ipad password reset
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Jul 25, 2013 | Apple iPod Audio Players & Recorders
When i plug my ipod on to itunes it wont show up
Sometimes your iPod fails to display in iTunes, which will keep you from being able to transfer songs from your computer to your iPod. If this happens, there are a number of steps you can take to resolve the issue.
Is it the iPod? Your iPod could fail to show in iTunes for a variety of reasons and this issue can be resolved by something as simple as rebooting your iPod. To reboot your iPod, first lay it on a flat surface. Using your thumb and index finger, press the play and menu button at the same time. If done correctly, your iPod screen will go blank and then you'll see the Apple logo. Is it the USB cable? Your iPod could fail to show in iTunes if you are using a defective USB cable. Try connecting your iPod to another computer that has iTunes installed using the same USB cable. If iPod again fails to show in iTunes, replace the USB cable. Is it my computer? One of the most common reasons your iPod doesn't show in iTunes is because your computer doesn't recognize your iPod is connected. Troubleshooting your computer/iPod connection Disconnect your iPod from the computer and reconnect. If your iPod still doesn't appear in iTunes, disconnect your iPod and reboot your machine. Once your computer has restarted, reconnect the iPod. Is it iTunes? Your iPod could be fail to display in iTunes if there is a issue with your iTunes program. If there is a problem with iTunes you can try updating the software to the most recent version. If that doesn't resolve your problem, re-install iTunes. b> http://www.itunes.com/ b> http://www.apple.com/support b> iPod Won't Connect to iTunes b> Apple's iTunes software contains mechanisms specially designed to sync with your iPod, allowing you to transfer music, videos and other media from your computer. If you find that iTunes does not recognize or allow you to access your iPod, then you cannot perform some of the device's most fundamental functions. Fortunately you can often resolve this problem without expensive maintenance, simply by doing a bit of troubleshooting and determining the cause of your connectivity problem.
Try resetting your iPod. Apple recommends this as a first step in troubleshooting an iPod not appearing in iTunes, since a quick reset will often restore functionality. If you use a click wheel iPod, hold down the "Menu" and center buttons until the Apple logo appears on your screen. For the iPod Touch, hold your "Home" button and "Sleep" button simultaneously until the Apple logo appears. Charge your iPod battery. If your battery has absolutely no power left, your iPod will often remain unresponsive even when plugged into iTunes. Try charging for three to four hours and then try connecting again. Plug your iPod into your computer using a different USB port. Sometimes a failed connection can mean you have a faulty USB port, so try plugging your USB cable into a different port and see if the iPod appears in iTunes. Verify that you have the latest version of iTunes. Visit the iTunes page Apple.com and check to see the latest version available. If you do not know which version currently runs on your computer, click "About iTunes." For Mac users, this option will appear under 'iTunes" on your menu bar. For Windows users, the option will appear under "Help" on your menu bar. Download the latest version of iTunes if necessary. Reconfigure your iPod service. If running iTunes on a Windows computer, click "Start > My Computer > Manage," and select "Services and Applications." Under "Services," select "iPod Service" and click "Stop." Leave the window open and connect your iPod to your computer. When your iPod shows up on your computer, click "Start." Reinstall iTunes. If simply updating iTunes does not work, you may have defective software. Try removing the program from your computer and completely and reinstalling it.
Jan 29, 2013 | Apple iPod touch Second Gen (8 GB,...
My ipod wont show up on the bar when i plug it in the itunes
I got a new 5th gen ipod nano not reconised by itunes
I found this article on apples web site I thought it might be helpful
http://support.apple.com/kb/TS3218
Apr 14, 2010 | Apple iPod nano 5th Generation
When I plug my ipod into my computer, it doesn't show up anywhere. Neither in "My Computer" or itunes. I'm running Windows XP Professional. I've tried resetting and forcing it to disk mode, reinstalling...
Maybe you should try this third ipod manager tool - Daniusoft iPod transfer:
Key-features:
1. Sync videos/songs from computer to iPod without iTunes ;
2. Backup videos/songs off iPod to computer smoothly ;
3. Transfer iPod video/music to iTunes .
I always use it to sync my iPod when my iTunes can't recognize my iPod, it's easy to use and works pretty well.
Dec 30, 2009 | Apple iPod nano
Ipod wont sync with media player
try to reset the ipodul download the new itunes and if does not work try to download a software called xilisoft ipod ipad iphone from torrent and you put what you want in your ipod with it
Aug 28, 2008 | Apple iPod classic MP3 Player
Ipod not recognized by computer or itunes
I cant transfer any song of my personal computer to my ipod,but when i format my ipod using my computer it was formated. what should i do to put music to my ipod?
Aug 01, 2008 | Apple iPod nano
Ipod nano
When I plug my ipod into my computer, it doesn't show up anywhere. Neither in "My Computer" or itunes. I'm running Windows XP Professional. I've tried resetting and forcing it to disk mode, reinstalling itunes, changed USB ports, and all the other possible solutions offered by the help web site. It was suggested that I take it to an Apple store for repair. It still plays music and videos that are downloaded on it, it just won't sync up with itunes.I have more music and videos that I wish to install on it.
Jul 14, 2008 | Apple iPod nano
Ipod 1st generation doesnt show up on itunes & wont restore
Do the 5 R's:
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
May 12, 2008 | Apple iPod nano
Ipod nano 3rd generation not recognised by computor
Right-click on your desktop, then click the Advanced tab. Then you should see on the lower left where it says screen resolution. Set this to 1024x768. This will allow you to see the setup assistant.
Dec 27, 2007 | Apple iPod nano
Apple iPod nano Logo
18 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
