Static is good - that means the receiver is working. You just need a good antenna to get the radio stations better. It should work with a CD player - connect one hear what that sounds. If it's good, then the amplifier is in good shape.
im just going to radio shack and return it for the only other one they have in stock which only goes to 512mhz whics stinks but at least i will recieve something wwhich is better than nothing
Check the squelch on your radio thats not recieving. If there is a monitor button ( when pushed you will hear static) try pushing it.. then get someone to call you so you can check if you can hear them.
On these radios you have 2 types of squelch....1 is called carrier squelch.... it basically opens when there is a strong enough signal. This lets you only hear strong signals and "squelch out" the distant ones and background static.
The2nd. is "tone squelch" ... with your radio they are often called privacy tones. If you have 2 radios set with the same privacy tones you will only be able to hear each other... only radios that are transmitting with that privacy tone will be heard on your radio. Its a high frequency tone that can't be hear by the human ear that gets "embeded" with the transmitting signal. The recieving radio hears it and opens the squelch.
So... if the radio thats rxing (recieving)your signal has its squelch set for just carrier squelch it will hear any signal thats strong enough to break the squech open.... basicaly any radio within a certain range. But if your radio (one with problem) has its squelch set for privacy tones you will not hear any other radios except the ones set with the same privacy tone.... the squelch will not open until it gets a tx signal with the right tone.... so if the txing (transmitting) radio is not using tone squelch but is using carrier squelch.... and the rxing radio is set for tone squelch... the rxing radio will not hear it.
With tone (privacy tones/codes) squelch you need a tone to open the squelch and then the audio can be heard... with carrier squelch the squelch will open if ANY radio is within a certain range.
Check the squelch setting on the problem radio... it could have a privacy tone set. Try pushing in the monitor button so you can hear static ( you want to hear everything including static) on both radios... tx on one radio at a time and listen if it can be heard on the other with the monitor button pushed.
If you can't hear any audio when the broken one is transmitting then it COULD be the mic.... if you can hear both radios with the monitor button activated than the radios are txing and have tx audio and are working... if thats the case its the privacy tones that are the problem.
Take care
It sounds like you have a problem with your phone line. If your machine has a reciever, pick it up or press the hook key. You want to listen to the dial tone. If there is any static in the line it will cause faxc problems. Also you can try disconnecting the fax and plugging in a standard phone into the wall jack. Make a phone call and aee if the line is clear or if there is static. If you do hear static in the line, first try replacing the phone line cord, from the wall to the fax, or phone. If that doesnt help then it is definatly a problem with the line and you must call the phone co. If the line is clear with the standard phone, and static with the fax reciever, or hook mode, then you may have a bad modem board in the fax. Let me know if I can be of further help! John
