Question about HP ScanJet 4100C Flatbed Scanner
Hp 4100c no sigen of life ... electrical problem? how to fix that??
Mij hp 4100 c ( still cool after all these years) sudddenly does not give a sign of life today
I took it to the office,, worked fine, came home and after connecting the usb cable and adapter nog sign at all.
Maybe i harrassed it too much while walking with it.
-It does inot give a single sign of movement.( as it always does when i hit the start button for the pc, the right one)
-the pc does not recognise anything being connected.
Maybe I burnt a fuse but could not find anything inside it.
I hit the green unlock switch several times; no reaction.
suggestions?
  • soer roes Jan 27, 2008
    Dear Friend,
    Thanks for your reply.
    First i am aware and I do understand that the HP 4100cc is extremely outdated but the easiness to use is just superb.
    So why not take a shot to repair it: oldies but still goodies.
    Laptop: Windows Xp .....Desktop at Home: also xp..
    But the problem is that it did not oworked at all after I soley used at work. It must be an electrical failure. But no fuse burnt. The adapter , delivers 30 volt power. I remenber dropping it in the car but after that it lighted up a 20 volt bulb wth no problem.
    Somebody knows which newer scanjet of Hp equals the easiness to this one?
  • jbpsdh Mar 09, 2009
    I have the same problem. My Scanjet 4100C scanner was working fine with Vista and VueScan until I rearranged my desktop which involved unplugging everything and rerouting the cables. When I powered everything back up the scanner no longer worked. I have no idea why unless something inside burned out when I powered everything down.
    Genius:
  • 2,985 Answers
What operating system ay work and at home?
Posted on Jan 25, 2008
Hp t1100 error 50.2
nstructions
  1. Remove the printer from any UPS supplies, additional power supplies, or power strips.
  2. Plug the printer into a wall outlet to check whether this resolves the problem.
  3. If the printer is already plugged in, try another power source in the building independent of the one being used.
  4. The line voltage and current source at the printer location might need to be inspected to make sure that it meets the printer's electrical specifications.
  5. Turn the printer off then on.WARNING: Be careful when removing or reseating the fuser. Temperatures can reach 400+ degrees Fahrenheit.
  6. If the message persists, turn the printer off for 30 minutes to allow it to cool, then reseat the fuser after checking the internal wiring connections on the right and left side, ensuring that these connections are properly seated.
  7. If the 50.1 or 50.2 error recurs after power-cycling the printer or when trying to print, try installing a known good fuser from another HP LaserJet 4100 series printer, if available.
  8. If the fuser is near or at the end of its estimated life expectancy (approximately 200,000 pages), then replace the fuser. After replacing the fuser, print a Configuration page, a Menu map (shows fuser settings), an Event log, a Supplies status page, and a Usage page, to reference the status of the new fuser and to ensure that the previous fuser settings are in place with the replacement fuser. To print an Information page on the HP LaserJet 4100, perform the following steps
    1. Press the MENU rocker key until INFORMATION MENU appears on the printer display.
    2. Press the ITEM rocker key until PRINT CONFIGURATION (or until PRINT MENU MAP, etc, appears in the printer display.
    3. Press the SELECT button to print the selected information page.
    To print an information page on the HP LaserJet 4100MFP, perform the following steps
    1. Press the MENU button.
    2. Press the DOWN Navigation button until INFORMATION is highlighted.
    3. Press the RIGHT Navigation button.
    4. Press the DOWN Navigation button to highlight PRINT CONFIGURATION (or PRINT MENU MAP, etc, appears in the printer display.
    5. Press the SELECT button, the button with the checkmark on it to print the selected Information page.
  9. If 50.x errors persist after properly installing a known good fuser, or if the errors follow the questionable fuser (provided it is not near the end of its estimated life expectancy), contact HP for further assistance.
Removing and replacing the fuser
Mar 23, 2013 | HP Designjet T1100 Photo Printer
Driver hp scanjet 4100c vista
Yo! I will have to direct you to a website where you can download anything for your computer. please follow the links below..
www.download.com
http://www.filehippo.com/
Aug 20, 2011 | HP ScanJet 4100C Flatbed Scanner
Where can I obtain a User Manual for a HP Scanjet 4100c
I found an equivalent for a user manual:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_task=useCategory&lc=en&dlc=en&cc=us&lang=en&product=58394
This will explain how to use the scanner and how to clean and maintain it plus there are faqs on the scanner as well with the link being on that page.
May 25, 2010 | HP ScanJet 4100C Flatbed Scanner
LaserJet 4350 Printer: 49.2f02 service error on hp 4100 printer...
Turn the printer off for a few minutes and then back on. If that does not fix the problem, try to have the print queue cleared and tray again. Most of the time it's a PDF file that causes this problem. If that does not fix it, it may need a new Jetdirect card.
May 16, 2010 | HP LaserJet 4350 Printer
Install hp 4100c to vista pc
There is a program called Vuescan which works with the Scanjet 4100C and Vista. Do a search for Vuescan and find a site where you can download it for around $30. I used Vuescan with my scanner until recently when my scanner died.
Feb 26, 2009 | HP ScanJet 4100C Flatbed Scanner
50 .2 Fuser Error in HP Laserjet 4100N
you need an maintenance kit 4100
ACC C8057A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8057-67901 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 110V, LJ 4100 LJ 4100 Series ACC C8058A 4100-mk-c4110a-mini.jpg Maintenance Kit, Fuser, 220V, LJ 4100 LJ 4100 Series
Selected Item RG5-5069-000 See RG5-5069-090 Not Available 0
Alternate Item(s) RG5-5069-090 Fuser Film ***'y, 220V, LJ 4100 180.50 2 http://www2.printerworks.com/cgi-win/tpwall.exe/find?RG5-5069-000
HP LJ 4100 Fuserkit RG5-5069 HP
Dec 11, 2008 | HP LaserJet 4100n Printer
I NEED A POWERCABLE FOR A SCANNER:HP SCANJET 4100c
You can go to the link below
www.shopping.hp.com
You can also
Shop by phone: 1 (888) 999-4747
I hope this has answered your question. If you have more questions please post a reply and i would be happy to assist. Thanks.
Oct 13, 2008 | Xerox Office Equipment & Supplies
Dark Background on HP Laserjet 4100
Several Options:
- Increase the Toner Density Level to 5
- Use freshly opened media
- Use a new print cartridge, if near end of life
- Run a cleaning page to clean the fuser
Jun 18, 2008 | HP LaserJet 4100 Printer
HP ScanJet 4100C Flatbed Scanner Logo
288 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
