Question about Ovens
Display has faded out to the point where it is difficult to read. What to do to repair? Replace a new display screen? How much the cost to repair it?
  • ntmurphy Jun 19, 2008
    Yes ... same exact problem. Can just barely see the clock, but temperature is completely dark. Rely on our own thermometer on the inside.
    So, is this something I can do? Where can I get DCS parts or generic parts for these ovens? Doesn't seem like it should be too tricky to throw a replacement in, but maybe I'm wrong.
    The DCS guy we've been referred charges $100 for a "diagnosis" visit (this after what has just been described), plus parts/labor for a fix. Seems like a rip-off.
    Any sites out there for parts? Thanks a lot.
  • 102 Answers
As the display is manufacturer and model dependent probably your only bet is to get it to a repairshop able to order a new display. my guess is that it is either a fluorescent display and the gas inside it has somehow leaked out, or when it's a lcd display the lcd crystals tend to have a disliking for heat and fade out in the long run. The cost could be anything from a few dollars for the screen ( if it's a generic one) plus labour, up to whatever the manufacturer charges for a replacement screen and hours spent on replacing it.
Posted on Jan 15, 2008
No electronic display. I read replacing C3 on the control board will fix. cau you confirm
On my stove the,
F1 - which showed after a minute of power. The clock didn't work but manual element and oven controls would. Basically the circuit board would not switch to 'digital'. After I checked the board components and seeing none were burned- I resoldered all the components except the chips( to rule out a 'cold' joint and replaced the largest capacitor near the display with a new capacitor of the same value but a higher voltage. PROBLEM SOLVED,
Cold solder joints are common and are very difficult to identify.
Fine point soldering/retouching all connections except the chips and replacing the caps have worked, and is an easy first step prior to a new board costing $$$'s. Mine cost 15 mins of time and $2.88 in caps. Give it a try..be precise with your soldering please.
Apr 29, 2015 | Ovens
Range has a very dim display
I have a Jenn-Air double wall oven with a very dim display light. Replaced c3 capacitor 68uf 35w - with a 100uf 50w cost $1.60 closes size available at Radio Shack and works good as new. Requires soldering onto the circuit board. I price a replacement part for $276.00.
Mar 19, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
The time on the oven slowly faded and you can not read what the time says
the display ( clock ) has failed and you will need to replace the e r c ( clock ) the part # is 74008259 and the cost is 272.85 plus shipping . I know you didn't want the hear this but this is a very common problem with clocks of all brands .. mm
Jul 11, 2010 | Jenn-Air JJW8230D Electric Double Oven
Fading digital display on Thermador SC302ZS Double Oven
when the display is fading it has to be changed part number 492071 that is for a double oven display
Feb 19, 2009 | Thermador C302U Electric Double Oven
Temp/clock display faided
its the display theat is fading away. I've haad meter's do the same thing after awhile and there's nothing you or I can do. Thanks for using Fixya
Dec 23, 2008 | Thermador SC302T Electric Double Oven
Display on our dcs oven is beginning to fade. can i fix it?
Hello just repaired my DCS wall oven. LCD screen is no good. part # lcd only is 211708. cost is $85.00 dollars with shipping. Took me twenty minutes to install. just need one philips head screw driver.Just call DCS Fisher@Paykel 1-888-281-5698 new Zealand.
Oct 03, 2008 | DCS WO-130 Stainless Steel Electric Single...
DCS elect wall oven LCD display
Had the same display issue with my DCS WOS-230. The display was fading and made it very hard to read clock and temp setting. Called DCS/Fisher Paykal and was told I need the Control system kit for $335.00 to fix the issue. After reading the input on this issue on this site I pushed them to sell me just the DCS EOC 211696 double display module 100-01095-00. Install took 10 minutes and everything works great. Thanks all for laying the groundwork as DCS will really push hard to sell you the more expensive kit that you do not need.
Jul 17, 2008 | DCS WO-130 Stainless Steel Electric Single...
Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Jul 07, 2008 | DCS (WOTD-227) Double Oven
Display problem
you can replace the display, however you have to take the face apart
Apr 27, 2008 | Whirlpool GBD307PDS Electric Double Oven
Jenn air oven display
the digital display on my jenn-air oven, model jjw9527c...has gone completely out. i am very efficient in wiring and electronics and would have no problem fixing it myself, just not sure which parts i need to order. Please return this with a solution, holiday season is very close.....thank u
Feb 09, 2008 | Jenn-Air JJW9527C Expressions Collection...
Ovens Logo
109 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
