ERROR CODE F204 on display , flashing add toner light, toner added but still have code.
  • Anonymous Mar 05, 2008
    light still flashing after toner was added
  • Soulvisitor
    Soulvisitor May 11, 2010
    Now where is that crystal ball of mine Damn can't find it, I know, how about you tell us the make and model.
Could you please let me know the right code for activation of the copy machine ???
Posted on Apr 22, 2009
Why does my kyocera 2026 display an error and says add toner even if I have already added toner?
because your dv unit is not agitating your toner these machines are notorious for this you can take out suspect color dv unit cover the toner hole shake the hell out of the unit smack the bottom a few times put it back in and if that works it will say adding toner it may overtone that color but running multiple copies will eventually clear the excess its best if you wrap the unit in a rag as well as cover the toner hole because toner will leak out when you shake it or replace that color dv unit but they are expensive if you don't know how to remove the dv unit try google or youtube try not to let anything come out when you shake it because there is developer as well as toner in there if you lose too much of that your unit will be worthless it wont ever be able to add enough toner to get add toner message to stop
Apr 08, 2017 | Kyocera 2026 Copier
Error message display (adding toner), but the catridge is full with toner.
cartage dispenser wheel might have broken,try with different cartage .
Feb 17, 2014 | Toshiba e-Studio 232 Black and White...
You can drop the toner cover and cheat the door sensor and watch the toner bottle to see if it spins or not. If it doesnt spin- the end result is not good especially if you have a grinding noise. or just the toner bottle not spinning and it asks to replace toner. The back of the machine will have to come off. You will have to remove all the covers and finisher off the front. Then get to the toner add mechanism and take it out. The one gear will probably be sideways because- if the customer put the toner in wrong or maybe the wrong toner in- it will bind and bend that back shaft. thereby screwing it up. It takes a lot of time and parts. First thing you need to do though- is to see if the bottle is spinning or not
Jul 25, 2012 | Minolta bizhub 250 Black and White Copier
What is C 710 error codes?
You machine toner is empty insert toner
Jun 14, 2009 | Kyocera KM-1505 Copier
Add toner is display on screen and phtocopier doesnot work
Some copiers have a switch that comes on when toner is low to get the light to go out you must ad toner In some cases the copier will not print until you add the toner
open front door there is usually a diagram that shows where to ad toner
Jan 06, 2009 | Panasonic DP-8045 Grayscale Copier
UF-788 Error Codes...
You have a bad laser unit, no parts are available anymore.
Nov 20, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Minolta Di200f copier
The error code has to do with the toner bottle/hopper. You just adde toner Right? Take the new toner bottle out and make sure not to spill any. Then close the doors of the copier and turn the main power switch OFF then back On. Let the copier warm up to Ready toCopy. Then reinstall the toner bottle and that should do it for you. The toner was out of HP when the toner was replaced. ... Good Luck
Oct 08, 2008 | Konica Minolta DiALTA Di200 Copier
Km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Oct 22, 2007 | Kyocera KM-1510 Copier
347 people viewed this question
