Miele W820 Drum does not spin
When drum should turn/spin, Rinse light flashes.
Water fills ok, filters ok, drive belt ok, drum turns freely by hand
5 Suggested Answers
  • 1294 Answers
SOURCE: Shocks broke, now drums spins freely
What you need to check thoroughly are the belt & the 2 shocks (dampers). The dampers should be replaced & fitted tightly, broader ends fitted below.
Posted on Mar 17, 2008
  • 868 Answers
SOURCE: hotpoint wf250 drum wont spin
Well if you see the drum move in the wash cycle than the belt is still attached.Your door latch is the first thing to check.And the control board is the next and most likely problem.
Posted on May 24, 2008
  • 111 Answers
SOURCE: Washing machine will not spin dry but washes properly
Posted on Nov 30, 2008
  • 20 Answers
SOURCE: Maytag washer won't Spin freely
You have a worn brake
Posted on Feb 10, 2009
  • 4 Answers
SOURCE: fills, and drains but will not aggitate or spin,
Try replacing the motor start capacitor.
Posted on Jan 25, 2011
0 characters
1 Points
Motor smell hot drum will not spin or pump out water Maytag atlantis
Im not an expert, but.Ok, but it wash? The only problem is at spin? if not wash at all:
Disconnect from the outlet, remove the belt, and by hand turn the pump and drum. Its suppose to move with low resistance in both directions, will not spin freely, but turn easy by hand. Do the same with motor. IF the drum and pump moves in both directions, I suspect about the motor.
If the only problem is at spin:
Do the same, but place special attention at the drum when you turn in reverse. Look if you see the brake Disk turn.
Nov 27, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Zanussi zwf 1221 will not turn drum, the end light flashes the water goes into the drum and drains out when a program is selected but the drum will not turn at all. You can turn it by hand and it moves...
you need to check the pressure switch inside the washing machine there a small hose connected with the pressure switch to sense that the level of water inside the drum is ok if this hose blocked the machine will not run
Oct 10, 2011 | Zanussi ZWF1430W Front Load Washer
Hi, Washer fills but drum does not spin, although drum is free.
no fault codes or flashing lights? has to be the drive belt. everything else is monitored by sensors. can you hear the motor spinning at all?
Jul 11, 2011 | Miele Novotronic W1918A Front Load Washer
My Bosch washing machine has a drum that no longer turns. When the cycle reaches a point where the drum has to turn, I hear a series of clicks and the spin does not work at all. I took the back off and the...
Check you can move the drum freely by hand. 1. if its free - then check belt. 2. if it wines - check motor. 3. if does not move - you need to check for obstruction. hope this helps ....
Jan 07, 2011 | Bosch WFMC 3200 Front Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
Tricity bendix aw1400w will not spin
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
Jan 22, 2008 | Tricity Bendix AW1400W Front Load Washer
Washing Machines Logo
392 people viewed this question
Top Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
