Question about Technics SL-1210 Turntable
Sound only from one channel
HELP!!!! So I am only gettin sound from one channel on both of my turntables. They are only about 2 years old as i got the for X-mas in 2005. I have checked everything i know to check and have found that the pins inside the tonearm when the needle cartridge connects are rusted, carodded, or something to that extent. Is there an easy fix to this or do I need to get new tonearms for both. I have heard rubbing alcohol and a q-tip but nervous to do anything as to not screw them up more. Please someone help me
Thanks
  • 102 Answers
Get hold of a multimeter and check the resistance from the leads in the shell (when connected to the tonearm) to the plugs at the other end of the cable. It should be zero or very near to zero.
Measure the resistance of the cartridge itself on both channels to see if it's at fault. Moving magnet cartridges should give somewhere between 500 and 1000 ohms, Moving coil a lot lower.
Use a high resistance setting in the multimeter to start with.
Color codes for headhell wiring:
Red = Right signal
Green = Right ground
White = Left signal
Blue = Left ground
When you measure much higher resistances or open circuits cleaning is indeed needed.
I clean small contacts like these with a fiberglass brush, which I think is/was sold as a sort of eraser in office supply shops, with a bit of alcohol on it.
You won't screw up anything by cleaning up a bit as long as you don't use any agressive cleaning fluids, plain old alchohol and gently scraping of the gunk will do.
Hold the cable ends with the clips firmly between tweezers and scrape around in them. When they do not fit snugly on the cartidge anymore after cleaning just gently squeeze them together a bit before re-installing the cartridge.
Posted on Jan 15, 2008
What caused no sound on ABC channels 2 and 21 only?
You would need to ask the broadcaster of the stations that question.
Mar 24, 2017 | Televison & Video
I have vestax 05pro2. Left channel works but out of one speaker. The turntable input is good. Im thinking Its either the channel fader, or the rca inputs for that side. Has anyone had this problem?
Here's a solution to see if you have a problem with either your receiver or turntable.
The turntable has 2 RCA's one red for right channel, and one white or black for left channel, which plug into the back of the amplifier.
  • Unplug both RCA from rear of amplifier.
  • Plug in a cd or dvd player into those inputs on the amplifier, the sound will be lower but it will give you an indication if the amplifier is ok or not.
  • If you have sound on both channels left and right then the amplifier is good
  • If you still only have sound on left channel, then there is a problem with the right channel input on the amp.
  • If your amp, is good, unplug the cd /dvd player.
  • Put a record on and start playing the record
  • Plug the white or black RCA from the turntable into the rear of the amplifier marked left, you should have sound.
  • now unplug it from the left and plug in into the right red RCA socket, if you have sound the amplifier is working fine.
  • if there is no sound there may be a problem with the stylus cartridge on the turntable
  • now lets reverse the test
  • unplug both RCA from amp.
  • Plug the red RCA into the left socket on amplifier, if there is sound, turntable is working fine, if no sound there is a problem with either the stylus cartridge or that red RCA cable.
  • now unplug the red RCA from the left side and plug it into the right side socket
  • if there is no sound there may be a problem with the stylus cartridge or RCA cable.
I hope this helps
MobileJB
Jul 15, 2011 | Audio Players & Recorders
I am only getting one channel when recording from Numark Ion Usb turntable, using Audacity software. The software is configured for stereo, but left track is not recording (and no sound from speaker...
Set your Audacity software to STEREO MIX on the main window. Go into EDIT, Preferences and set the recording device to your sound card and the channels to 2 stereo.
Mar 07, 2011 | ION Audio iTTUSB Turntable
The sound of the ''shure m44-7'' only sends a signal to the left side of my headphones and master. the cables are wired in the good colour and seem to be steady, what else could it be?
If you are only getting sound from one channel try reversing the left and right channel cables from the turntable to the Preamp/Amplifier. If the sound switches channels in your headphones then the cartridge or the cables from the cartridge to the preamp in the turntable have a problem. If the same channel has sound, did not change channels, then you have a problem with the preamp or headphones. If the headphones work with another input, radio, cd, etc, then the headphones are good and the problem is in the preamp unit.
Jun 17, 2010 | Shure M44-7 Turntable
No sound on channel 69 on my philips tv LCD
use youe remote and make sure sound setting are in Stereo mode Not SAP
Nov 02, 2009 | Philips 42PFL5332D 42 in. LCD Television
No sound from one channel
hi!change your rca connector..first..ok
Jun 07, 2009 | Technics SL-1200MK2 Turntable
I was wondering what the extra wire attcahed to the audio cords it looks like a speaker wire
the bare stripped wire is for grounding the turntable to the receiver to eliminate any hum sound. If after connecting both phono plugs, you only get sound from one channel on the turntable but sound plays out of both channels on all other inputs then replace the phono plugs as this is the most likely problem.
May 27, 2009 | Audio Players & Recorders
Sony PS-LX300USB Turntable, one channel not working
Have you tried swopping over the output leads from the turntable to the amp (normally one red and one white phono plug) so they are in each others socket? If you do this and you still get no sound from the right channel it is almost certain to be a faulty amp,or speaker.
If you swop and get no sound from the LEFT channel it is could be either a faulty lead or cartridge.
Apr 19, 2009 | Sony PS-LX250H Turntable
Gemini tt02 no sound!
phono \line switch the right way maybe.have you got signal on the mixer from dodgy deck
Aug 20, 2008 | Philips gemini TT-02 Turntable
Technics SUV500 Amplifier
check volume balance between right and left-then change inter connection between sound source and amplifier with new cabel(i prefer gold plated type connectors)(see radio shack).
after that if the problem excit your fault in output transistors or output stereo ic depend on circuit design.
Feb 17, 2008 | Technics SUV500 2-Channel Amplifier
Technics SL-1210 Turntable Logo
135 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
