Switching on problem Goodmans tvc201t
Pressing the power on button, a continous ticking sound is heard. Upon pressing the button again, the standby light flashes once and the tv is dead.
  • Anonymous Jan 27, 2008
    Mine does the same! Usually after a power cut or when the plug has
    been turned off at the wall. I had been able to get it going a few
    times by switching it on and of with the remote, but now my remote has
    died I'm stuck. Would be grateful if you had a solution.
    Tracey
We had the same television and when it came on after a power cut it just did this clicking thing. We rang up but we were told it would be too expensive to fix. It got chucked.
However, coincidentally, we happened to be given another television of the same model by someone who was moving abroad. The same thing happened when it was unplugged from the mains while on stand-by. Having seen the half-solution above, I tried pressing the on button on the remote but it just kept clicking away. I tried various buttons, including ones on the television itself. Eventually after much button pressing, it made the initial noise like it was about to fire up but then went back into clicking mode. But by keeping on pressing buttons, it seemed to make more and more of an effort to turn on, which eventually it did.
As it happens, the final button pressed was on the remote control, but I think any button will do. So don't give up if your remote doesn't work. Just keep pressing buttons, and it might just gradually build up a head of steam until it turns on. This could take a good few minutes. I've no idea what might have actually happened. Someone posted the same problem elsewhere on the internet and someone suggested it might be something to do with the capacitor.
Posted on Dec 14, 2008
I have a quartz infrared zone heater and I need to know how to reset from celsius to regular heat
There you go
OPERATION INSTRUCTIONS
FUNCTION
POWER
The POWER button supplies power to all the functions of
the heater. Pressing the POWER button again the heater will
be put in standby mode.
Pressing and holding the POWER button on the control
panel for 3 seconds will switch between °F and °C.
Dec 25, 2017 | Heating & Cooling
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
14.2.2 To Make a Diagnosis
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
    Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Dec 10, 2014 | Panasonic Heating & Cooling
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
Server ON only by pressing power on button continously otherwise server downs & no display
where the cable for the power sw connects to the motherboard your polarity might be reveresed. Therefore, try switching the plug-in the other direction (groung and colored wires).
Sep 18, 2012 | IBM eServer xSeries? 3400
Switch TV on then a blank red screen appear then a green and then a blue which then just repeats that sequence of colours every second. The remote control packed up working some month before. - 2 year old...
turn TV on, let the Tv cycle through the three colours, then using the remote press the menu button followed by the standby button. press standby button again and it all comes up working.
andy
Sep 20, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
Sudden power failure
my swisstec tv had exactly the same problem this week march 30th and the 12 month warranty expired.....i went to skymediauk online and extended my warranty ..free for 3 months they collected it,fixed it and returned it in 46 hours
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
Televison & Video Logo
210 people viewed this question
Top Televison & Video Experts
