Question about HP D530C W2K PRO
VGA card MY built in VGA is not working on my pc and i want to disable it to let the VGA card work. How can i solve this problem and the screen is off becauze of the VGA.
    Brigadier General:
  • HP Master
  • 3,614 Answers
This is the best thing you can do, reset the the CMOS setup by removing the battery, and the jumper switch to clear CMOS and then power ON and OFF the computer, return back the battery and also the clear CMOS jumper on its original settings.. and then your done. Power ON the Computer..
Note: the clear CMOS jumper can be seen always near the battery or in the lower right part of the motherboard. it has has 3 pin and the default setting is must be 1 , 2 and the pin 3 , 4 is also for clearing the CMOS. ü
Posted on Jan 15, 2008
Well i connect the vga cable to the sreen and my computer but when i turn tht computer on the screen stays black ...i need help!!
Hi Omar,
Do you have a built-in vga port on your desktop as well as a video card with a VGA slot? Make sure you are plugging it into the correct one. If there are two you will need to specify in the BIOS to disable the built-in VGA port or use the other one.
Also, if you only have one and the vga port is on a video card, turn off and unplug power to the computer then make sure the video card is fully seated in the correct slot.
Do you here a sequence of beeps? If your computer is beeping, your motherboard manual includes a list of "BEEP codes" that indicate what problem your motherboard is reporting which could be memory, cpu or video related.
Mar 23, 2011 | Computers & Internet
Why is there no signal when i connect my desktop to my flat screen?
if its you tv flat screen you might have to go to the menu and select pc on that...if its your pc flat screen make sure its connected fully to blue vga connection and turned the right way up...hope this helps
Oct 13, 2010 | E-Machines eMachines Desktop PC
Vga card is dead so the nothing showing on the screen
On motherboards with built in video cards when you plug in a new card the on board card is automatically disabled. Just plug the card in and connect your monitor.
I hope this helps, if so please rate our solution.
Corporate Computer
Dec 12, 2009 | Gigabyte GA-8VM800PMD-775 Motherboard
Sound card stopped working
1st you disable the onboard sound card in BIOS level, then install/update the sound driver for Maddog Prowler 4.1 DSP soud card will solve your problem.
Dec 08, 2009 | Mad Dog Multimedia Prowler 4.1 DSP Sound...
Video driver disabled. restarted. no beep and black monitor
  1. Turn on the PC
  2. As it is booting, keep tapping the F8 key until options appear on a black screen (you should see these)
  3. Choose VGA Mode option (or similar)
  4. Then enable your driver again or reinstall it
Computer Support Services
Jun 07, 2009 | E-Machines eMachines Desktop PC
Will only work with agp slot
i would get another agp card and be done with it. these cards can be very cheap now. keep the pci graphics card in the hp. i'm sure that is better than the onboard graphics. good luck.
Apr 21, 2009 | MSI KT3 Ultra2-R Motherboard
How to disable onboard video on DC7600?
hello, sometimes if you disable on board VGA on your baord, the vga card will still not work well but i will tell you how to disable ooboard vga on your sytem anyway( got to the bios settings on your computer, select pheripheral setup and disable onboard vga.)
Dec 17, 2008 | HP Compaq dc7600 PC Desktop
Lost AV cable in a move
Radio Shack have all sorts of cables.
E-mail Voodoo3 technical support for a cables
Try a cheap PCI VGA card on your PC , then instal the AV after it; it might not stand alone.
Good luck
Feb 04, 2008 | 3dfx Voodoo3 3500 TV (16 MB) Graphic Card
How to disable onboard VGA
I believe if you install an AGP card the onboard VGA is supposed to be automatically disabled. Did you buy an AGP card?
Nov 28, 2007 | Foxconn P4M800P7MA-RS2 Motherboard
Computers & Internet Logo
159 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
