FixYa.com
Tags:
Copiers
Generic problem for all Copiers
Sharp AR-157E digital copier
posted by gafxitmn on Jan 15, 2008
F2 flashing on display , add
Toner light flashing and when I press the print button an 04 is displayed . What does it all mean and can I fix it or reset it ? Thanks Steve.
Comment by gafxitmn, posted on Jan 16, 2008
Thanks doctorx for your suggestion , I dont see a chip on the cartridge , will try another cartridge , thanks .
gafxitmn
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 22, 2008
Not Rated (0)
takle
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
sir i have a problem with sharp AR-5320 copier it blinking H and 4 can you help me please
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
doctorx
Rank:Guide Guide
Rating: 82%, 5 votes
The AR-157 has a chip on the back of the toner cartridge, you would need to check and make sure it doesn't have toner on it, or replace the cartridge, it is probably defective.
Rating Locked! (?) gafxitmn has rated this solution as Not Rated
This Problem Also Relates To: HP 280 Copier Panasonic DP-C354 Copier Panasonic DP-8020E Black and White Copier Panasonic Workio DP-3530 Grayscale Copier Panasonic FP-7735 Black and White Copier Panasonic FP-D605S2 Grayscale Copier Panasonic Workio DP-1820E Copier
Can you Help with these Copiers problems?
Toshiba e-Studio 161 Copier Copier
when i on copier it display H-4...
hi can you help me with the... Answer This...
Copiers
blotches
my Xerox Workcentre M15 has... Answer This...
Canon PC-920 Black and White Copier
Paper Jam light
After I run one copy through... Answer This...
Copystar CS-2030 Copier
Copy star 3035
I have a CS 3035 that puts tiny... Answer This...
Copystar CS-3035
I have an original that is... Answer This...
Repair Service
Find Copier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
