Question about Sony STR-DE925
No display, no sound
My STR-DE925's display has gone black and is not allowing any of the components (TV, DVD, VCR, etc.) to have any sound the individaul components are on and playing, but there is no sound.
Any suggestions?
  • 1 more comment
  • Anonymous Jun 04, 2008
  • Anonymous Jul 16, 2008
    Same problem . arrive after the protec have no responding.
  • Anonymous Feb 12, 2009
    no display no sound just died when on
Same problem. arrive after protec not responding
Posted on Jul 16, 2008
2 Suggested Answers
6ya staff
SOURCE:
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: My STR-DE925's display has gone
So it's dead in other words.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Posted on Aug 24, 2011
Missing main power button for sony STR-DE925
If there is no other issue than the fact that the power switch button which is the customer control knob, you must try and source a similar type or getone from a scrapped set which might not be a big issue. Check with repair centers where you can find luck.
Oct 25, 2011 | Sony STR-DE925
My STR-DE925's display has gone black and is not allowing any of the components (TV, DVD, VCR, etc.) to have any sound the individaul components are on and playing, but there is no sound. Where can I...
Aug 23, 2011 | Sony STR-DE925
My STR-DE925 reciever isn't giving me any sound. When i turn it on everything works like normal, kicks on, and there is a click; but after a few seconds the display switches from whatever input it was on...
check speaker connections.sounds like the system is trying to stop some thing more serious happening by shutting itself down.a pain yes but saves blowing something up.if no luck,then definately send in for repair
Oct 17, 2010 | Sony STR-DE925
Sony STR-DE925 auto-decode has worked fine for years. All DVD/PS3/Cable is attached to TV via HDMI and inbound audio from HDTV is optical fiber (TOSLINK). Up until today, this has worked perfectly, i.e.,...
OK, so with more troubleshooting, I was able to eliminate the problem with my DE925. It was actually the Vizio HDTV that was causing the problem, as I decided to route the optical audio from my DVD and PS3 directly to the same TOSLINK port on the DE925 and auto-decode worked. It was not the fiber-op cables either. This HDTV was a less-expensive 720p 32" model anyway, so I am not too concerned with the optical out working on it as I can run up to four TOSLINK connections in to the receiver.
Jan 02, 2010 | Sony STR-DE925
May i know the model no. of the remote of str de925 , where can i buy one.thanks
RM-LJ301 It can be purchased "new" on EBAY for 27.99 Hope this helps
Jul 24, 2009 | Sony STR-DE925
Only dvd plays properly but vhs will not show picture.
Most likely you have the dvd part connected through component or svideo cables. Despite the fact that this is one unit, like other vcr/dvd combo units it acts as two separate units in the same box. The vcr will probably not play through those cables. As you have audio coming through I'd imagine that the audio is connected using red and white composite cable. Connect the video on the vcr side with composite yellow cable or run direct to tv with a coaxial cable.
Feb 04, 2009 | Sansui VRDVD4005 DVD Player/VCR
Lost manual...I cannot get DVD or VCR to record
You need to decide which set of inputs or outputs you want to use. To record, and watch what you have recorded on your TV, you will need TWO sets of audio/visual patch cords. One for recording and the other for playing. Let's start with the recording. Look for the Line in or video in plugs on your DVD-VCR unit. Some recorders have separate inputs for the VCR and DVD. Others let you select with the remote. Usually Line 1 is at the back and Line 2 is on the front. Your remote will have "recording source" to let you select, or sometimes you can use the channel up and down arrows to select your input source. Your remote will also allow you to select either the DVD or VCR for recording. Connect the Yellow plug to the Video In socket, and the red and white plugs to audio in., Connect the other end of the cord to the TV or cable box. Yellow goes to Video Out, red and white go to audio out. Recording from the cable box is much easier because you wiull always have a signal going into the DVD-VCR recorder no matter what happens at the TV.  Now look for the Video out connection on the DVD-VCR recorder. Connect the Yellow plug to video out and the red and white plugs to audio out. Ignore the other connections at this point. They are for RGB component video. Your DVD -VCR should have one output for both functions. Use that one.
Now connect that cord to a Video one or Video 2 input on your TV.
Test the set-up. Play a DVD or a VHS tape and try to bring it in using the TV remote.
Then turn on a program and try to record it on  the DVD-VCR, then play it back.
This sounds very complicated, but all that's involved are two patch cords with three plugs on each end - 12 connections in all and color-coded. YELLOW is always video.
Dec 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Getting Surround to work
The easiest way is to hook up your DVD/VCR combo directly to the back of your Sharp LCD TV, then run a component audio output from the TV to the audio input in the back of the receiver. Make sure you hook up your front, center and rear speakers correctly to the receiver, then go through with the speaker calibration steps - per manual, then it should work with no problem. Good luck!
Marc
Sep 07, 2008 | Sony STR-D665 Receiver
Sony STR-DE925 Logo
358 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
