Question about Espressione Caf? Retro Cappuccino/Espresso Maker - Silver
Espresso maker my krups espresso maker will not use all the water i pour into it. maybe only half will get used. it will continue to steam but no water will come out. we do not have hard water here, and i have flushed it with vinegar to no avail.
  • 37 Answers
Sounds like you need to remove the coffee oils from the Brew Head Screen and filter basket which a decalcifier and vinegar will not touch.
Starbucks cleans theirs every night.
info:
soak the Brew Head Screen, unscrew from the brew head where the coffee oils come into contact with machine, and filter holder in a coffee oil remover by www.urnex.com or dezcal.
Posted on Nov 20, 2008
  • 2,039 Answers
I understand you say you dont have hard water you should clean with decalcifier just to get that calcium out of there vinegar is not strong enough it good for a regular coffee machine it not expensive and it does the job dont forget to rinse the machine very good that stuff is very corrosif cheers
Posted on Jan 15, 2008
Krups Vivo 880. Steam wand is acting as a faucet
The steam valve is not closing. In such a case water finds an east exit from the machine where there is no back pressure.
Repair the steam valve.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Dec 25, 2016 | Krups Coffee Makers & Espresso Machines
Makes a bang sound and spit sout steam
Try first to pour out some hot water first from steam wand and then try to make coffee.
Jun 30, 2010 | Krups Small Appliances Espresso Machine
Recently my Krups 4050 espresso machine starting beeping repeatedly while making espressos. Same thing every time: espresso starts to pour out then machine beeps like something's wrong and doesn't finish...
It needs a new flow meter. I replaced the one in mine and now it works fine. I took the old one apart and the little magnet inside is a ferrite magnet which rusts over time when it comes in contact with water ( duh). If the new one does this I am going to just replace the little magnet with a rare-earth magnet which will cost about $1 or less and shouldn't rust out. I am wondering if the company changed the magnet in the new flow meter so this doesn't happen or if planned obsellesants, just last long enough to get it out of warranty, is the company's motto. The new flow meter was around $30 when the added the $9 for shipping.
May 19, 2010 | Krups Cappuccino/Espresso Maker -...
The hot water and steam commes inside the machine KRUPS FNF1
The mashine dont pull water from the water container and it ask us to press hot water , but nothing happend when we press , anyone knows how to sole this question ?
Allan
Dec 30, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Steam frother
1. Pour in vinegar instead of water. 2. Bring vinegar to a boil but do not run it through the machine. 3. Turn off machine for the machine for an hour. 4. Remove sheath from the steamer. 5. Place tip of steamer into large mug of cold water. 6. Turn espresso machine on and allow vinegar to run through steamer.
Optional: Before starting the process, unbend a paperclip or metal hook (for hanging holiday ornaments) and use it to clear the steamer orifice.
It may take the vinegar a little while to dissolve and loosen the blockage. If the process does not work the first time time, try again later and allow the warm vinegar to sit in the machine longer.
Jun 19, 2008 | Krups Allegro FND111 Espresso & Coffee...
No steam comes to milk frother
Try this: 1. Pour in vinegar instead of water. 2. Bring vinegar to a boil but do not run it through the machine. 3. Turn off machine for about an hour. 4. Remove sheath from the frother and clean the metal tip. 5. Place tip of frother into large mug of cold water. 6. Turn espresso machine on and allow vinegar to run through frother. 7. You'll know the frother is clear when the water in the mug begins to churn rapidly (and perhaps loudly).
Optional: Before starting the process, unbend a paperclip or thin metal hook (the kind used for hanging holiday ornaments) and use it to clear the steamer orifice.
To keep frother clear: Follow recommended descaling schedule in user manual
Jun 05, 2008 | Krups Allegro FND111 Espresso & Coffee...
Steam generator
hard water build up in steamer tubes a good clean with clr should help remedy this make sure maker is completly cleaned after using clr cleaner
May 15, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups XP4030 is stuck in the steaming mode
Here is a link for the manual. It says on Krups web sight they have a 1 year warranty,
http://www.krupsonlinestore.com/manual/55360.pdf
Nov 02, 2007 | Krups XP4030 Espresso Machine
Water not coming through espresso side although steam wand works fine
you both can have same problem, solution is:
  1. low pressure of pump (or too fone grinded coffee)
  2. security valve of boiler openes to early and dont let the pump to rise pressure enough for good brewing( if it is this you can see water returning back to container if you have 2nd pipe in your machines reservoir)
Oct 05, 2007 | Krups Bravo Plus 872 Espresso Machine
Espressione Caf? Retro Cappuccino/Espresso Maker - Silver Logo
217 people viewed this question
Top Espressione Coffee Makers & Espresso Machines Experts
Douglas Dinnebeil
Douglas Dinnebeil
Tom Chichester
Are you an Espressione Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
