Question about Westell Wirespeed LiteLine 6100 (B9961001002) Modem
Can not connect
Everything is hooked up. The onlything thatlights up is the power and the dl lights. I just had a overhaul on my computer and a new ethernet card put in. Where I had it fixed they could access the internet, but I get nothing.
    Genius:
  • 1,224 Answers
Rerun your network setup wizard again this should bring back your modem and access
DsL is a glorified phone connection its not smooth and is always in a state of flaux along with your neighbors there neighbors so on and so forth
technecoly i would run cable connection that does not flaux with neighbors always have a strong signal
DsL is slow as 58 bit data fax modem i found it a waist of money and time waiting for system to play catch up
your comps fine its just your service provider
Posted on May 09, 2008
I have Toyota Land Cruiser Model S-HDJ81V-RNPCX (1 HD-T) and recently I was doing a major overhaul the engine, everything was fine except the gear. It's seem like gear 1 and gear 2 didn't work. Looks
check that you have hooked up all the cable connections properly. run fault codes and look for TCM problem. Have a pressure test done on the transmission as there may be band/clutch adjustment problems.
Jan 31, 2014 | 2001 Ford Escort ZX2
My toshiba is charging but onlythe cord out lets bliking what does that mean
Plug the adapter into the wall outlet or power strip. If using a power strip, make sure the strip is on. Most laptop power adapters have a small LED light; the light will illuminate when power is being transferred from the outlet to the adapter. If the light illuminates, chances are you have sufficient power to supply your laptop. Wiggle the power cord if the LED light did not initially illuminate. If the light turns on and off when you wiggle it, you might have a loose cord in the adapter, or the outlet could be faulty. Plug the adapter into another power outlet, preferably a different circuit in another room, if the LED light did not illuminate the first time. If it lights up from the second outlet, the first outlet either does not work or other devices were using too much power on the initial circuit. Connect the other end of the adapter to the laptop and turn the laptop on. When the computer starts up, you should see an indication of how the laptop is being powered in the lower right-hand corner. If you see a battery icon, then the laptop is being powered by the battery, not the adapter. Make sure both ends of the adapter are securely connected. If they are, and if the LED light on the adapter is lit, then you likely have a faulty wire that is not properly connecting to your computer. If you see a plug or adapter icon, then the laptop is successfully being powered by the adapter. If the LED light on the adapter is not lit, then the bulb is out, but the adapter is still working.
Jan 20, 2013 | Toshiba Satellite Pro L300 Notebook
Not powering on at all - I have been built a new computer from scratch with all brand new components. After hooking all of them up and plugging in the power source. Nothing is happening when the power...
1. Could be as simple as not having the Power Switch on the right jumper...double check.
2. The board will power up with nothing hooked to it... just power, CPU, MEM... disconect everything to just to get the board up to the bios.
3. Make sure PS is securly connected to the MB.
4. Check Jumper on the Board to make sure the Test Jumpers are not set
5. Memory is seated correctly... if you pull them out the board will start and beep...
Dec 31, 2009 | Gigabyte GA-G41M-ES2L Motherboard
MY acer aspire L320 Aspire wont even turn on! everything is connected its been ugraded to 2GB RAM and but thats the onlything thats not standard on it.. any thoughts?
take out one stick of memory and see if came on if still same result take out the modem ( last pci slop on the board ) if still dont came on try new power supply thanks
Oct 25, 2009 | Acer Computers & Internet
Router Wont COnnect To Internet
Reboot your modem, router, and computer. Power them all down (unplug the modem and router if necessary) then boot the Modem, then after a minute boot the router, then your PC and see if all is well, it should be.
Jul 24, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Need to finish my car but dont know how to get wiring diagrams with listed colors
Robbie, doing a harness overhaul with diagram is a mess, try a salvage yard to find harness you need, or look for one in remanufactured books for your car. I have done harnesses from scratch and can't tell you what a pain it is getting it right and fixing plugs for origional connections. If you find one at salvage take it out yourself so you understand how to hook it up. This is without a doubt the best advice that can be given in this case.
Apr 26, 2009 | Ford Mustang Cars & Trucks
Computer worked fine, unhooked it to hook up a new one, decided to hook the emachine back up to play games on, got it hooked up but it won't come on now. everything is hooked up right, i opened it up and...
make sure you hook everything with a little force especially the memory until it snaps back into place. same goes for all the cards. care should be give to the cpu, nice and easy. make sure your power supply is potential enough or has not gone bad. The MB can give a green light but there could be too little energy for the whole system.
Mar 27, 2009 | E-Machines Emachine T5026 power supply **...
Cant connect!
- Try to power cycle the Motorola modem and the router for 5 minutes.
- After 5, turn On first the modem, make sure all the lights of the modem are stable before plug in the router.
- If this procedure doesn't work then I suggest that you might need to update the firmware of your router.
Mar 15, 2009 | D-Link DI-624M Router (DI624MRE)
American legacy II LA690 amp
MOST LIKELY THE AMP IS BLOWN TRY TO CONNECT ONE SPEAKER AT ONCE TO SEE IF THE IS SOUND IF THERE IS YOU HAVE THE WRONG OHM LOAD
May 13, 2008 | Car Audio & Video
Westell Wirespeed LiteLine 6100 (B9961001002) Modem Logo
162 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
