1. there is a sensor at the end of the printer which shows paper jam recovery. the sensor of your printer may be jammed. clear the jam and it will work.
2. if not, there may be a small piece of paper near the sensor of your printer. clear it.
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button.
Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
The flashing red light next to a page and bin indicates paper or a CD/DVD has jammed in the printer.
The flashing red light next to the drop indicates that the ink is low - if it is solid on then the ink is out.
Both of these lights flashing rapidly together means taht the print head carriage is obstructed by jammed paper or some other material and cannot return to the home position. Turn off the printer then open the paper support and the printer cover. Then remove any paper or other obstructions from the paper path by hand / tweezers. Then, turn the printer back on and the fault should clear. If the lights are stioll flashing then check the paper path again and see if the print head carriage assembly is jammed by gently moving it very slightly along the carriage. Don't force this or do this too hard or too far as you can cause some damage to the drive
There are actually some certain meaning on the red light and green
light showing different information to user. The summaries are: 1) Green On, Red Off = Printer Ready. 2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up. 3) Green Fast-Flashing, Red Off = Printer off-line. 4) Green Slow-Flashing, Red Off = Processing Data. 5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing. 6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset. 7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted. 8) Green Off, Red Off = Printer power is off. 9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode. 10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
Often the paper jam light will stay on when the *back* paper jam door is not cleared.
Open up the back of your printer. There is a 2nd door behind this door that you can pull open. If there is a paper in this section, pull it out and it should clear your red light.
When clearing paper jams, clear the front first, and then if the red light is still on, you need to check the back hidden door for another piece of paper.
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!!
Go to http://.i18nguy.com
