Home | Philips | 30PF9946 30 in. HDTV-Ready Plasma Television | HDMI quit working
Philips 30PF9946 30 in. HDTV-Ready Plasma Television
Problem for Philips 30PF9946 30 in. HDTV-Ready Plasma Television
HDMI quit working
By Hoytkiller on Jan 15, 2008
I use this tv for a PC monitor, HD satellite viewing, and XBOX 360. I was having intermittent problems with the HDMI audio bleeding in to the other inputs. Sometimes if for instance I turned on the PC, I could hear the audio from the HDMI output on the satellite receiver through the TV speakers. Other times, I might just hear a crackle in the audio when in PC mode. If I switched back and forth between HDMI and PC inputs a couple of times, both issues would go away. I tell this just as background to what happened next. Since I have my PC hooked to the VGA input on the TV, I have been forced to manually switch the HDMI input from the Satellite receiver to my XBOX 360. (Sorry, I was too cheap to buy the $100 switch). Anyway, I usuall make this switch hot (TV on, Satellite receiver on, but XBOX off. This system although a pain, was working until yesterday. I was watching HD satellite, when I decided to play XBOX. I switched the HDMI cable, but when I turned the XBOX on, it wouldn't start up. I immediately assumed my XBOX had crapped out , but when I switche the HDMI cable back to the satellite, the TV would not recognize the signal. I have since tried the XBOX and satellite on another tv with HDMI, and both still work fine. I am thinking that some sort of switch in the tv has gone out, but I don't know. Should I just junk this TV for a new 1080P? My problem with doing that is that I use PIP with the PC on one side, and HDMI on the other. This tv does that, but I can't find another tv that does.
Popular Solutions for Philips 30PF9946 30 in.
Questions and Unsolved Problems for Philips 30PF9946 30 in.
Do you recommend Philips 30PF9946 30 in. HDTV-Ready Plasma Television?
Answer
Answer
When I am in the user menu, I acannot change or even see the tint adjuster and a couple of the... (More)
Answer
just recently purchased a sharp lcd television i am having a problem connecting it to my durabrand... (More)
Answer
trying to get owners manual for vimax 32 plasma tv
Answer
Have you fixed it or gotten rid of it yet? Because if not, I have a solution for you. I had the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 30PF9946 30 in....:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
