Emerson PDE-2717 portable DVD won't read disc
When I try to turn it on, it says "loading" for awhile, then I get "Bad disc". It also sounds a little noisy. Any suggestions would be appreciated!
  • 1 more comment
  • sweigl Feb 23, 2008
    This is not related to power, since it happens with just the main unit, without the second screen. And, I have it plugged into the cigarette adapter, not battery power.
  • faith_m99 Jun 24, 2008
    I have the same problem with my Emerson PDE 2717, says loading for a while, then BAD Disc reading. Is there anywhere to get these fixed?
  • katyareed May 02, 2009
    I have the same problem. Is there anywhere I can get the unit repaired? I don't really think it is related to the Powersource
I believe it is related to power as this issue started on one of these after turning on both screens. i am still dealing with millenium 3000 over a purchase of the same unit. i am going to be trying a 4th unit 'when new stock arrives' but i doubt it.
Posted on Feb 23, 2008
The dvd player will not read the disc
If it won't read any disc you put in, consider getting a new DVD player, the eye is most likely gone bad. If it is only one disc that you can't read i would suggest a Scotch DVD Cleaner kit. Cleans and Repairs discs, helps prevent skipping and mistracking, and repairs minor surface scratches improving disc audio and image quality.
Jul 28, 2011 | Cyberhome CH-LDV1010A Portable DVD Player
No longer loading dvds
You may have a bad laser. First, make sure the laser assy. travels back and forth easily, then make sure the table the disc sits on spins freely. If it still isn't reading, load a disc and immediatly flip it over to it's top and see if it works. Working or not, still a bad laser.
Feb 12, 2009 | Audiovox D1708 Portable DVD Player
My portable dvd player is not working good
It sounds like U have a bad lens. Try a lens cleaner. If it is the lens, it wont read anymore discs. Sometimes it will also make a clicking sound and show disc error/no disc cryptic messages on the screen.
Dec 23, 2008 | Polaroid PDM-1058 Portable DVD Player
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
Emerson PDE 2717
I also needed a new screen to screen power cord. Call 1-866-553-7521 and give them the model # PDE 2717. Ask specifically for the screen to screen power cord because the first cord the see when they do a look-up is the car to screen cord. The cost was $6.00 but adding in shipping brought the total to $15.99. Expect the delivery in 7 to 10 business days. Thanks and enjoy!
Apr 04, 2008 | Car Audio & Video
Emerson PDE-2725N DVD player
My PDE 2625n worked on the way to Mimi's and starting on the way home it displayed "Disk Loading..." then errord out with "Bad Disk". I dug through the internet and over 3 days found the answer.
Your laser is tired. Since the DVD player is cheap, replacing it is not worth the $$. Fix it! Remove the back cover (about 10 small phillips screws). It is important to know that their is a back plate AND a back panel; remove the PLATE which should have a model number sticker.
Now you should see a circut board with a set of polished rails which holds the read head. On the read head (by a ribbon cable ) are two very, very, very small flat blade POT screws. These control the amount of power sent to the laser. Turn the right most one CLOCKWISE about a 1/8 to 1/4 turn.
You can test your handy work by popping in a DVD while the cover is off and seeing if it loads. If all is ok, put it back together. If not turn it a little more. I used a car battery charger to run my test since it's about 25 degrees outside.
Be aware the more power sent to the laser, the faster it burns out (according to my research). By feeling is the DVD player is broke, so what? Am I going to break it? What the hell;) and I cranked away.
BTW I just got this fixed this morning. My kids are screaming with joy for DVD's in the car again! I'm thrilled that I don't have to spend $100 or more to replace this unit.
Cheers!
Ap
Nov 16, 2007 | Car Audio & Video
Emerson PDE-2717 Portable DVD Player - worked great for a few months but now just says 'Bad Disc' even when using discs that work in other players.
I had same problem, took the back cover off. two scews that are right were the ribbon connects to the read head I believe are potentiometers adjusted with eyeglass screw driver a couple attempts it worked. I also disconnected the plug for external battery and left unpluged since I don't use battery
Sep 18, 2007 | Audiovox D1812 Portable DVD Player
How can i fix my portable dvd player?
that noise sounds like the focus is trying to see the disc as it has to focus to see or register there's a disc. Maybe the turntable slipped down a little or there's dirt or film on the lens. Good luck
Apr 26, 2006 | Durabrand 8.5'' Portable DVD Player
Televison & Video Logo
391 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
