Back to:
Tags:
Jenn-Air JGS8750 Gas Kitchen Range
JGR8855 (by 3 users)
posted by Jessie1 on Jan 15, 2008
F9 code, what should I do?
Thanks Liz
Comment by Jessie1, posted on Jan 15, 2008
can anyone help?? Have a company dinner to cook tonight...yuk
Thats exactly what it was, thanks so much
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Annie92502, posted on Apr 20, 2008
I have the same problem with my oven. I am getting the F9 code and it comes back when I hit the clear button.
Comment by mrsbpd, posted on Mar 12, 2008
An F9 error code is on the display, and it was also beeping & the oven door is locked. I tried pressing the Stop/Clear button, but the F9 error code came back on and the oven door continues to be locked.
Clarification Request
by tech17, posted on Jan 15, 2008
was you trying to clean it before cooking also should be more than 9 on code but fyi 9 is a door lock fault also post the coplete model number off the serial plate try clear cancel to see if code clears
Solution #1
Not Rated (0)
tech17
Rank:Guru Guru
Rating: 88%, 1054 votes
did pause cancel do it if so dont run self clean till you finished with you dinner do i get my four boxes
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on JGR8855:
I don't want to Accept this solution
Can you Help with these Kitchen Ranges problems?
When we run the oven self-clean, the oven interior...
When I press "clean" key, it beeps twice, but...
Just came home and I think the power went out while I was...
other burners make a clicking sound when only one burner...
one burner is not working - ignition does not spark good...
Loading problems.
Repair Service
Find Kitchen Range Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
