Question about Nu Mark AXIS 9
Axis 9 One of my units has lost the scratch funtion it also locks up periodically. I recently started using serato scratch live and the axis 9's are really acting strange.
  • Anonymous Dec 09, 2008
    I somewhat have the same problem but my scratch mode only work in puase or cue. I dont know how to fix it.
Because Scratch Live uses a time coded CD in the Axis 9, your options are limited as the turntable can't manipulate the signal as it does with regular CD's. Here are your options:
1. Only use scratch mode 4 - wherever you set your cue point is where the scratch will start and return upon touching but you will be able to release and continue playing.
2. Set your Serato to absolute mode to give you pitch control and key locking from your Axi9. Scratch mode 4 will work properly in absolute mode.
3. When turning on your turntables make sure you allow 10 seconds to pass before touching the jog wheel or loading your Serato disks.
4. When loading tracks in Scratch Live give a second or two before manipulating them with your turntables.
5. Try purchasing midi adapters, cable and software, you can assign the Scratch Live functions to your CD decks, it's time consuming and you still won't be able to use the effects but this may give you more control.
Posted on Dec 23, 2008
I have exactly the same problem, its annoying
1 thing which works is holding the button down then spinning the deck round, let go, turn off the scratch button, press play and turn on the scratch button again
Posted on Jun 16, 2008
Axis 9"s skipping
I solved this exact problem by re-calibrating the units follow this link to see how :) http://www.numark.com/images/product_downloads/axis9_recalibration.pdf
Dec 27, 2013 | Nu Mark AXIS 9
DW079 CALIBRATION
Here is how you get your laser into adjustment modeY axis; Power and scan key at same time, unit then will tip from Y1 to Y2, then recenter. use up and down arrows to bring laser into adjustment. Let unit stabilize for 30 seconds, press scan key, you will get a continuos beep, now at same time press down arrow key. This will store your new calibration.To get X axis into adjustment mode power on and up arrow at same time, and for Z axis type laser onto Z axis and use adjustment procedure for Y axis. Saving your calibrations is the same as in Y axis. Hope this helps you
Jan 04, 2012 | Office Equipment & Supplies
Whilst using my axis 9 it released a burning smell (rubber) and just turned off. Now it won't even turn back on and still has a cd inside.
bad capacitor on the inside of the unit.
usually the 10000uf 16v tall cap blue or black cap.
look for a bulge on the top.
replace it with a higher voltage cap.
Mar 12, 2010 | Nu Mark AXIS 9
My axis 9 wont play burnt cds
I'm having the same problem with the Axis 9 I just purchased on eBay. And so is the person who posted "Numark Axis 9's. . Problematic. Ahhhh!!!" Seems ridiculous that this would be so common. I definitely don't want to re-burn 100's of CDs just to use this CD player.
Nov 08, 2009 | Nu Mark AXIS 9
I have the rumble pad 2 and need to know how to move the camera
right stick x-axis>axis properties>map x-axis to>mouse x axis. do the same for y axis. if you download the latest profiler. it has a tutorial.
ftp://ftp.logitech.com/pub/techsupport/joystick/lgs502.exe
older version has to be uninstalled first you will not loss your profile setting by uninstalling the older version.
Jul 22, 2009 | Logitech Dual Action for Pc (963292-0403:)...
Axis 9 - Doesn´t work properly. It´s crazy !!!!!
your set needs to clean and service have a tech do the work on your set.good luck
Apr 01, 2009 | Nu Mark AXIS 9
Using other sound cards with serato scratch live
Using pc onboard sound cards with serato scratch live
Jun 08, 2008 | Rane Serato Scratch Live Computer DJ...
Nu Mark AXIS 9 Problem
u are probably using scratch mode 2, hold prog and scratch to change between different scratch mode, if this doesnt work, i recommend u take your jog wheel for cleaning
Nov 07, 2007 | Nu Mark AXIS 9
Parts for numark axis 9
Numark address in the UK is: NUMARK UK LTD UNIT 9, THE CHRISTY ESTATE IVY ROAD ALDERSHOT GU124TX UNITED KINGDOM Tel: +44 1252 341 400 I would give them a call. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 31, 2007 | Nu Mark AXIS 9
Cd players locks up when power switched on
arg... email numark they will give you a uk brach to email - there is a reset facilty that may help you (sorry cant rememeber the buttons it was yonks ago) while it sorted mine 'scratch' is now permanently lit only... they suggested a servide to clear that one prob but got used to cueing the record on that deck in scratch mood which is an art in itself lol
Sep 18, 2006 | Nu Mark AXIS 9
Nu Mark AXIS 9 Logo
294 people viewed this question
Top Nu Mark Audio Players & Recorders Experts
robert landry
 Ian Kayhan
Ian Kayhan
Are you a Nu Mark Audio Player and Recorder Expert? Answer questions, earn points and help others
