Question about Hotpoint WF430 Front Load Washer
Washing machine My hotpoing washing machine has a test light that has just appeared what is going on.
  • 121 Answers
You can find out on the manual you can get it here
http://www.hotpointservice.co.uk/hs/pages/manual/manualSearch.do
Posted on Mar 03, 2008
WF740 Aquarius washing machine keeps going through a Test cycle. Cannot get it to wash?
Turn off the appliance at the mains, hold on & start buttons down then turn back on at mains and hold until dOFF appears should now be back the normal.
Oct 20, 2014 | Hotpoint Washing Machines
My hoover washer dryer wont start? No power
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
http://www.espares.co.uk/advice/washing-machines/a/7/1298/how-to-replace-washing-machine-controls-hotpo.html
Click for tips to repair
Jun 28, 2012 | Hoover Washing Machines
My washing machine kkeps tripping my fuse box
This is related to a fault in the main control panel, it is possible there is a short if the fuse keeps tripping off. You need to remove plug and pull out the panel to check for short in the power supply to the main control panel usually a SMPS unit. Use a multimeter to check for short, if so this must be replaced.
check for tips from the link below:
Apr 30, 2012 | Hoover Nextra HNF 3157 Front Load Washer
HOW CAN I GET MY HOTPOINT AQUARIUS 1400 - OFF CONSTANT TEST PROGRAM?
This works
To exit the TEST mode, press and hold down the "Start/Cancel" button until ALL of the console lights light up. Press both "Start/Cancel" and On/Off buttons simultaneously until " dOFF " appears in the display. The default setting will now appear and the machine can be used normally.
Feb 04, 2008 | Hotpoint Washing Machines
Display lights
make sure there water going to machine, remove fill hose to see check inlet filters.good luck eire
Dec 07, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WF430 Front Load Washer Logo
61 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
